กดปุ่มสั่งงานในแอพ blynk แล้ว esp8266 รีสตาร์ทครับ
ปรึกษาหน่อยครับ คือผมต้องการกดปุ่มในแอพ blynk แล้วส่งข้อความไปไลน์ แต่กดแล้วบร์อดรีสตาร์ท ตลอดเลยครับ
#define DHTPIN D4 // what digital pin we're connected to
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
#define LINE_TOKEN "x" // แก้ Line Token
char auth[] = "Tx";
int measurePin = A0;
int ledPower = D2;
int samplingTime = 280;
int deltaTime = 40;
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
float d = dustDensity;
float t; // Declare the variables
float h;
WidgetLCD lcd(V0);
pinMode(ledPower, OUTPUT);
Serial.println("DHTxx test!");
Blynk.begin(auth, "WTF", "xxxxxxxxx0!", "blynk.honey.co.th", 8080);
// Serial.printf("WiFi connecting to %s\n");
// while (WiFi.status() != WL_CONNECTED) {
// Serial.print(".");
// delay(400);
LINE.notify("PM 2.5: ");
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(1, 0, "Air measurement"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
lcd.print(5, 1, "Monitor");
BLYNK_WRITE(V5){
Serial.println(param.asInt() );
if (param.asInt()== 1){
LINE.notify("PM 2.5: "+String(dustDensity)+" µg/m³");
lcd.clear();
lcd.print(3,0,"Off The Light");
lcd.print(5,1,"<<NOW>>");
// LED.off();
// digitalWrite(LED1, LOW);
//BLYNK_WRITE(V5)
// LINE.notify("PM 2.5: "+String(dustDensity)+" µg/m³");
// // You'll get HIGH/1 at startTime and LOW/0 at stopTime.
// // this method will be triggered every day
// // until you remove widget or stop project or
// // clean stop/start fields of widget
// Serial.print("Got a value: ");
// Serial.println(param.asStr());
digitalWrite(ledPower, LOW); // power on the LED
delayMicroseconds(samplingTime);
voMeasured = analogRead(measurePin); // read the dust value
delayMicroseconds(deltaTime);
digitalWrite(ledPower, HIGH); // turn the LED off
delayMicroseconds(sleepTime);
// 0 - 3.3V mapped to 0 - 1023 integer values
// recover voltage
calcVoltage = voMeasured * (3.3 / 1024);
dustDensity = 0.17 * calcVoltage - 0.1;
dustDensity = dustDensity * 1000;
Serial.print(" - Dust Density: ");
Serial.print(dustDensity);
Serial.println(" µg/m³");
Blynk.virtualWrite(V3, dustDensity);
Blynk.virtualWrite(V4, voMeasured);
// เช็คถ้าอ่านค่าไม่สำเร็จให้เริ่มอ่านใหม่
if (isnan(h) || isnan(t) || isnan(f))
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print(t);
Serial.print(" *C ");
Serial.print(f);
Serial.print(" *F\t\n");
Blynk.virtualWrite(V1, t);
Blynk.virtualWrite(V2, h);
// if (pm1>=30){
// LINE.notify("PM 1.0: "+String(pm1)+" ug/m3");
ขออภัยที่ตอบช้า ครับ ควรย้าย การส่ง ค่าเข้า line ไปไว้ใน void loop ในปุ่ม v5 แทนค่า logic true/false ส่งไป tigger ใน void loop ให้ส่ง line แทน
ประมาณไหนครับ พอมีตัวอย่างไห้ศึกษาไหมครับ
char auth[] = "Tx";
int ledPower = D2;
int deltaTime = 40;
float h;
bool lock = false;
WidgetLCD lcd(V0);
    // delay(400);
BLYNK_WRITE(V5)
     if (param.asInt()==1) {
         lock = true;
         lock = false;
//BLYNK_WRITE(V5)
    // recover voltage
    Serial.print(h);
    Serial.print(t);
    Serial.print(f);
    // if (pm1>=30){
     if (lock == true)
        LINE.notify("PM 2.5: " + String(dustDensity) + " µg/m³");
        Blynk.virtualWrite(V5, LOW);
        lock = false;
    }else
        lcd.clear();
        lcd.print(3, 0, "Off The Light");
        lcd.print(5, 1, "<<NOW>>");
ไม่ค้างแล้ว ขอบคุณมากครับ
