สอบถามหน่อยค่ะ คือใช้ time.h แล้วรันได้ปกติ แต่แสดงวันที่และเวลาผิดไปหมดเลยค่ะ แสดงเป็นปี 1970 ต้องแก้ไขยังไงหรอคะ (ต่อกับบอร์ด esp8266 )
เปิดโค้ตตัวอย่าง ของ timer.h ให้ดูหน่อยครับ
ใน example หรอคะ
ใช่แล้วครับ
#include <NTPClient.h>
#include <WiFiUdp.h>
const char *ssid = "<SSID>";
const char *password = "<PASSWORD>";
WiFiUDP ntpUDP;
// You can specify the time server pool and the offset (in seconds, can be
// changed later with setTimeOffset() ). Additionaly you can specify the
// update interval (in milliseconds, can be changed using setUpdateInterval() ).
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", 3600, 60000);
void setup(){
WiFi.begin(ssid, password);
while ( WiFi.status() != WL_CONNECTED ) {
delay ( 500 );
Serial.print ( "." );
timeClient.begin();
timeClient.update();
Serial.println(timeClient.getFormattedTime());
วางโค้ตเต็มให้ดูหน่อย
// Set these to run example.
#define WIFI_SSID "ssszet_2G"
#define WIFI_PASSWORD "0951182015"
// Define NTP Client to get time
WiFiUDP ntpUDP;
//Week Days
String weekDays[7]={"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
//Month names
String months[12]={"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"};
// Initialize Serial Monitor
// Connect to wifi.
Serial.print("connecting");
Serial.print("connected: ");
timeClient.begin();
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
unsigned long epochTime = timeClient.getEpochTime();
Serial.print("Epoch Time: ");
Serial.println(epochTime);
int currentHour = timeClient.getHours();
Serial.print("Hour: ");
Serial.println(currentHour);
int currentMinute = timeClient.getMinutes();
Serial.print("Minutes: ");
Serial.print("Seconds: ");
Serial.print("Week Day: ");
Serial.println(weekDay);
//Get a time structure
int monthDay = ptm->tm_mday;
Serial.print("Month day: ");
Serial.println(monthDay);
int currentMonth = ptm->tm_mon+1;
Serial.print("Month: ");
Serial.println(currentMonth);
Serial.print("Month name: ");
Serial.print("Year: ");
Serial.println(currentYear);
//Print complete date:
String currentDate = String(currentYear) + "-" + String(currentMonth) + "-" + String(monthDay);
Serial.println(currentDate);
หากใช้โค้ตตัวอย่างวันที่ตรงไหมครับ
ไม่ตรงเลยค่ะ
แสดงเวลาไม่ได้เกี่ยวกับโค้ตเราแล้ว ลองหา library ตัวอื่นทดสอบดู
ลองเอาตัวนี้ไปเทสดูครับ
ลองแก้ตามที่บอกแล้วค่ะ แต่ก็ยังแสดงค่าเหมือนเดิมค่ะ
ลองแก้ระบบเวลาดูครับ
Code ให้ลอง
#define WIFI_SSID "Nu-Electronic"
#define WIFI_PASSWORD "228228228"
//NTPClient timeClient(ntpUDP, "pool.ntp.org");
const long offsetTime = 25200; // หน่วยเป็นวินาที จะได้ 7*60*60 = 25200
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", offsetTime);
//Week Days
//Month names
// Connect to wifi.
timeClient.begin();
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
// timeClient.offsetTime(3600);
ตอนนี้สามารถใช้ได้แล้วนะคะ ลองเปลี่ยน WiFi ดู ก็ใช้ได้เลยค่ะ
ง่ะ อย่าบอกนะว่า ไม่มีเน็ตใน อันเดิม
