ขอคำชี้แนะด้วยครับ คือผมต้องการเชคการกดปุ่ม V3 V4 V5 V6 หรือ V7 ถ้าปุ้มไหนมีการกด แล้วพอเรากดปุ่ม V10 จะให้ทำตามคำสั่งที่เราต้องการหนะครับ
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
#define EspSerial Serial3
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
//=======Connect Server=======================
char auth[] = "xxxxxxxxxxx";
char ssid[] = "Office2.4G";
char pass[] = "glnvdgdj'";
//=======End Connect Server=======================
//====Values WidgetLED=============================
WidgetLED LED_L1(V30);
WidgetLED LED_L2(V32);
WidgetLED LED_L3(V34);
WidgetLED LED_L4(V36);
WidgetLED LED_L5(V38);
WidgetLED LED_R1(V31);
WidgetLED LED_R2(V33);
WidgetLED LED_R3(V35);
WidgetLED LED_R4(V37);
WidgetLED LED_R5(V39);
//====END WidgetLED=============================
WidgetLCD LCD(V0); // LCD
BLYNK_CONNECTED(){
//====set LED off=====
LED_L1.off();
LED_L2.off();
LED_L3.off();
LED_L4.off();
LED_L5.off();
LED_R1.off();
LED_R2.off();
LED_R3.off();
LED_R4.off();
LED_R5.off();
//====End set LED off=====
Serial3.begin(115200);
Blynk.begin(auth, wifi, ssid, pass, server, port); //Reguler server
//=============Button Open=================
BLYNK_WRITE(V10){
int btV10 = param.asInt();
if (btV10 == 1){ //button V10 ON
if(V3 == 1){
LED_L1.on();
}else if(V3 == 0){
LED_L1.off();
}else if(V4 == 1){
LED_R1.on();
}else if(V4 == 0){
LED_R1.off();
}else if (btV10 == 0){ //button V10 Off
Blynk.virtualWrite(V3,0);
Blynk.virtualWrite(V4,0);
Blynk.virtualWrite(V5,0);
Blynk.virtualWrite(V6,0);
Blynk.virtualWrite(V7,0);
//=============Button V3=================
/*BLYNK_WRITE(V3){
int btV3 = param.asInt();
if (btV3 == 1){ //trun on LED Left
Serial.print("btV3 = ");
Serial.println(btV3);
}else if (btV3 == 0){
