C:\flutter\bin\flutter.bat --no-color pub get
Error detected in pubspec.yaml:
Expected "flutter" section to be an object or null, but got [{family: Chakra Petch, fonts: [{asset: fonts/ChakraPetch-Regular.ttf}, {asset: fonts/ChakraPetch-Bold.ttf, style: italic}]}].
Please correct the pubspec.yaml file at C:\Users\Admin\scoredy\pubspec.yaml
description: A new Flutter application.
# The following line prevents the package from being accidentally published to
# pub.dev using `pub publish`. This is preferred for private packages.
publish_to: 'none' # Remove this line if you wish to publish to pub.dev
# The following defines the version and build number for your application.
# A version number is three numbers separated by dots, like 1.2.43
# followed by an optional build number separated by a +.
# Both the version and the builder number may be overridden in flutter
# build by specifying --build-name and --build-number, respectively.
# In Android, build-name is used as versionName while build-number used as versionCode.
# Read more about Android versioning at https://developer.android.com/studio/publish/versioning
# In iOS, build-name is used as CFBundleShortVersionString while build-number used as CFBundleVersion.
# Read more about iOS versioning at
# https://developer.apple.com/library/archive/documentation/General/Reference/InfoPlistKeyReference/Articles/CoreFoundationKeys.html
version: 1.0.0+1
environment:
sdk: ">=2.7.0 <3.0.0"
dependencies:
flutter:
sdk: flutter
# The following adds the Cupertino Icons font to your application.
# Use with the CupertinoIcons class for iOS style icons.
cupertino_icons: ^1.0.1
image_picker: ^0.6.7+21
google_fonts: ^1.1.2
dev_dependencies:
flutter_test:
sdk: flutter
integration_test:
sdk: flutter
# For information on the generic Dart part of this file, see the
# following page: https://dart.dev/tools/pub/pubspec
# The following section is specific to Flutter.
flutter:
- family: Chakra Petch
fonts:
- asset: fonts/ChakraPetch-Regular.ttf
- asset: fonts/ChakraPetch-Bold.ttf
style: italic
# The following line ensures that the Material Icons font is
# included with your application, so that you can use the icons in
# the material Icons class.
uses-material-design: true
# To add assets to your application, add an assets section, like this:
assets:
- images/basketball_background.jpg
# An image asset can refer to one or more resolution-specific "variants", see
# https://flutter.dev/assets-and-images/#resolution-aware.
# For details regarding adding assets from package dependencies, see
# https://flutter.dev/assets-and-images/#from-packages
# To add custom fonts to your application, add a fonts section here,
# in this "flutter" section. Each entry in this list should have a
# "family" key with the font family name, and a "fonts" key with a
# list giving the asset and other descriptors for the font. For
# example:
# - asset: fonts/Schyler-Italic.ttf
# style: italic
# - family: Trajan Pro
# fonts:
# - asset: fonts/TrajanPro.ttf
# - asset: fonts/TrajanPro_Bold.ttf
# weight: 700
# For details regarding fonts from package dependencies,
# see https://flutter.dev/custom-fonts/#from-packages
ลองแก้ส่วนนี้เป็น
flutter:
fonts:
- asset/fonts/ChakraPetch-Regular.ttf
- asset/fonts/ChakraPetch-Bold.ttf
style: italic
หรือ
flutter:
fonts:
- fonts/ChakraPetch-Regular.ttf
- fonts/ChakraPetch-Bold.ttf
style: italic
ลองแล้วRun ได้ปกติครับแต่เหมือนนำไปใช้ไม่มีผลอะไรเลย
Fonts มันไม่มาใช่ไหม
ใช่ครับผมก็ไม่รู้ทำไง
ให้จัดวางโปร์เดอร์ใหม่ครับแบบนี้
แล้วปรับโค้ตอ้างอิงแบบนี้
fonts:
- family: ProductSans
fonts:
- asset: packages/receipt_widget/fonts/Product-Sans-Regular.ttf
- asset: packages/receipt_widget/fonts/Product-Sans-Italic.ttf
style: italic
- asset: packages/receipt_widget/fonts/Product-Sans-Bold.ttf
weight: 700
จากนั้น เรียกใช้งานโดย
Text(
'Using the ProductSans font from the receipt_widget',
style: TextStyle(
fontFamily: 'ProductSans',
package: 'receipt_widget',
แก้ชื่อด้วยสิ
asset: packages/scoredy/fonts/xxxx.ttf
เรียกใช้งานรึยัง
อัพโหลดไฟล์ app ไว้หน่อยครับ
