ติดข้อผิดพลาด error: redefinition of 'class BlynkTimer' ครับช่วยผมด้วยครับ
    Sketch generator:           http://examples.blynk.cc
    Blynk community:            http://community.blynk.cc
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - ESP8266 board
   - Decide how to connect to Blynk
     (USB, Ethernet, Wi-Fi, Bluetooth, ...)
  There is a bunch of great example sketches included to show you how to get
  started. Think of them as LEGO bricks  and combine them as you wish.
  For example, take the Ethernet Shield sketch and combine it with the
  Servo example, or choose a USB sketch and add a code from SendData
  example.
#include <SimpleDHT.h>
// DHT Config
int pinDHT22 = D5;
SimpleDHT22 dht22;
// SET Timer
char auth[] = "sDbAW5umkRUDSbfEvj_PBlJdwhs2L3z6";
char ssid[] = "Nongdang_2G";
char pass[] = "0816096445";
void sendTemp()
  float temperature = 0;
  float humidity = 0;
    Serial.print("Read DHT22 failed, err="); Serial.println(err);delay(2000);
  // to avoid delay() function!
ดูตามนี้ครับ
