หาคนช่วยหน่อยครับ esp 8266 ชอบรีเซตตัวเอง
#include <time.h>
#include <PZEM004Tv30.h>
#include <EasyScheduler.h>
int timezone = 7*3600;
int dst =0;
#define Relay1 D5
#define LED D6
PZEM004Tv30 pzem(D7,D8);
WidgetTerminal terminal(V40);
//ตั้งค่าคีย์สำหรับการเชื่อมต่อจุดต่างๆ
char ssid[] = "--------------";
char pass[] = "-----------";
char auth[] = "-------------------------";
#define LINE_TOKEN  "---------------------"
int T1=0;
int L1=0;
Schedular Task1;
Schedular Task2;
  WiFi.begin(ssid, pass);
  Serial.println("Wi-Fi connected");
  Serial.print("IP Address : ");
  LINE.notify("ระบบไฟเริ่มทดสอบใช้งานแล้ว");
  pinMode(D5,INPUT_PULLUP);
  Blynk.begin(auth, ssid, pass, IPAddress(00,000,000,00), 8080);
  pinMode(D5, OUTPUT);
  pinMode(D6, OUTPUT);
  configTime(timezone,dst, "pool.ntp.org","time.nist.gov");
    Serial.println("\nWaiting for time");
    while (!time(nullptr)) {
  Task1.start();
  Task2.start();
  time_t now = time(nullptr);
  if( (p_tm->tm_hour == 11) && (p_tm->tm_min == 30 )){
  if(L1 == 1){L1=3;LINE.notify("ไฟชั้น 1 กำลังเปิดอยู่");};
  if(L1 == 0){L1=3;LINE.notify("ไฟชั้น 1 ปิดแล้ว");}
  Task1.check(volt, 5000);
  Task2.check(reconnectwifi ,4000);
  if (param.asInt() == 1)
    Blynk.virtualWrite(V1, 1); //On
    digitalWrite(D5, HIGH);
    T1=1;
    LINE.notify("ระบบไฟเปิดแล้ว");
    AutoMode();
   Blynk.virtualWrite(V1, 0); //Off
   digitalWrite(D5, LOW);
   T1=0;
   LINE.notify("ระบบไฟปิดแล้ว");
   AutoMode();
void AutoMode(){
  if (T1 == 1){
    Serial.println("T1=1");
    L1 = 1;
  else if (T1 == 0 ){
    Serial.println("T1=0");
    L1 = 0;
void volt(){
        Blynk.virtualWrite(V30,voltage);
        Blynk.virtualWrite(V31,current);
    float power = pzem.power();
        Blynk.virtualWrite(V32,power);
    float energy = pzem.energy();
        Blynk.virtualWrite(V33,energy);
        Blynk.virtualWrite(V34,frequency);
    float pf = pzem.pf();
        Blynk.virtualWrite(V35,pf);
void reconnectwifi(){
  if(WiFi.status() == WL_CONNECTED){
    terminal.clear();
    terminal.println("------------------");
    terminal.println("WiFiConnect : OK ");
    terminal.println(WiFi.localIP());
    terminal.flush();
  else{
    terminal.clear();
    terminal.println("WiFiConnect : Failed :( ");
    terminal.flush();
  WiFi.reconnect();
ปัญหาเป็นแบบนี้ครับ เวลาเปิด blynk แล้วมันก็ reset เองอันนี้ไม่แน่ใจเป็นที่อะไร
อุปกรณ์ที่ใช้ esp8266,PZEm-004t
แคปหน้า serial มาดูหน่อยครับ ว่ามันขึ้นยังไง
ถ้าอย่างนั้นลอง ตัดชุด Pzem ออกไปก่อน ให้เหลือเฉพาะชุด Wi-Fi connect กับ Blynk ดูครับ ดูให้มันใช้ได้ก่อน จากนั้นค่อยๆ เพิ่มทีละอย่างเข้าไปครับ :blush:
