Connecting to oasiskit.com:8080 ครับ อยู่ๆก็เป็นครับ
//#define D0 13
//#define D1 10
#define statusLED D7
#define TRIGGERPIN D1
#define ECHOPIN D2
char auth[] = "TOKEN"; //Token key
char ssid[] = "Net24g";
char pass[] = "1234567";
//char led1 = D0;
//char led2 = D1;
long distance = 0.0;
long alertValueIn = 10.0;
long alertValueOut = 20.0;
String text_In = "";
int cntIn = 0;
  int pinValue = param.asInt();
  Serial.print("Slider ==> ");
  Serial.println(pinValue);
  alertValueIn = pinValue;
BLYNK_WRITE(V4)
  alertValueOut = pinValue;
  pinMode(D1, OUTPUT);
  pinMode(statusLED, OUTPUT);
  analogWriteFreq(500);
  analogWriteRange(100);
  WiFi.begin(ssid, pass);           //เชื่อมต่อ WiFi
  Blynk.connect();                  //เชื่อมต่อไปยัง Blynk
{ // ฟังก์ชันนี้ทำงานเมื่อต่อ Blynk ได้
  Blynk.virtualWrite(V4, alertValueOut);
  Blynk.virtualWrite(V2, alertValueIn);
  distance = readUltrasonic();
  Blynk.virtualWrite(V5, distance);
  if (distance <= alertValueIn || distance >= alertValueOut)
    text_In = text_In + " , " + distance;
    Blynk.virtualWrite(V1, text_In);
      Blynk.virtualWrite(V3, 1);
      //      digitalWrite(D7, HIGH);
      analogWrite(statusLED, 100);
      delay(4000);
    Blynk.virtualWrite(V3, 0);
    //      digitalWrite(D7, LOW);
    analogWrite(statusLED, 0);
  if (text_In.length() > 35)
    text_In = text_In.substring(25, text_In.length());
long readUltrasonic()
  long duration, distance;
  digitalWrite(TRIGGERPIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGERPIN, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHOPIN, HIGH);
  distance = (duration / 2) / 29.1;
  Serial.print(distance);
  Serial.println("Cm");
  return distance;
ใช่ได้รึยังครับ
