ช่วยผมดูหน่อยครับ ESP8266 WifiManager
เคยใช้งานได้ปกติ แต่อัพกับบอร์ดใหม่ ไม่ทำงานครับ มันขึ้น
Invalid settings in EEPROM, trying with defaults
[code]
   1MB flash sizee
   sonoff header
   1 - vcc 3v3
   2 - rx
   3 - tx
   4 - gnd
   5 - gpio 14
   esp8266 connections
   gpio  0 - button
   gpio 12 - relay
   gpio 13 - green led - active low
   gpio 14 - pin 5 on header
#define SONOFF_BUTTON    D3
#define SONOFF_RELAY    12
#define SONOFF_LED      2//13
//#define SONOFF_INPUT    14
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
static bool BLYNK_ENABLED = true;
#define EEPROM_SALT 12663
typedef struct {
  int   salt = EEPROM_SALT;
  char  blynkToken[33]  = "";
  char  blynkServer[33] = "blynk-cloud.com";
  char  blynkPort[6]    = "8442";
} WMSettings;
WMSettings settings;
#include <ArduinoOTA.h>
//for LED status
#include <Ticker.h>
#define D0 5//1
#define D2 4//2
#define D4 14//5
#define D5 13//7
Ticker ticker;
WidgetLED led1(10); //virtual pin 10
WidgetLED led2(11); //virtual pin 11
WidgetLED led3(12); //virtual pin 12
WidgetLED led4(13); //virtual pin 13
WidgetLED led5(14); //Status Online
const int CMD_WAIT = 0;
const int CMD_BUTTON_CHANGE = 1;
int cmd = CMD_WAIT;
int relayState = HIGH;
//inverted button state
int buttonState = HIGH;
int buttonState1 = HIGH;
static long startPress = 0;
static long startPress1 = 0;
void Status()
  int v1=digitalRead(D0);
  int v2=digitalRead(D2);
  int v3=digitalRead(D4);
  int v4=digitalRead(D5);
  if (v1==1){ Blynk.virtualWrite(10, 0); }else{ Blynk.virtualWrite(10, 255); }
  if (v2==1){ Blynk.virtualWrite(11, 0); }else{ Blynk.virtualWrite(11, 255); }
  if (v3==1){ Blynk.virtualWrite(12, 0); }else{ Blynk.virtualWrite(12, 255); }
  if (v4==1){ Blynk.virtualWrite(13, 0); }else{ Blynk.virtualWrite(13, 255); }
void tick()
  //toggle state
  int state = digitalRead(SONOFF_LED);  // get the current state of GPIO1 pin
  digitalWrite(SONOFF_LED, !state);     // set pin to the opposite state
//gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager) {
  Serial.println("Entered config mode");
  Serial.println(WiFi.softAPIP());
  //if you used auto generated SSID, print it
  Serial.println(myWiFiManager->getConfigPortalSSID());
  //entered config mode, make led toggle faster
  ticker.attach(0.2, tick);
void setState(int s) {
  digitalWrite(SONOFF_RELAY, s);
  digitalWrite(SONOFF_LED, (s + 1) % 2); // led is active low
  Blynk.virtualWrite(6, s*255);
void turnOn() {
  relayState = LOW;
  setState(relayState);
void turnOff() {
  relayState = HIGH;
void toggleState() {
  cmd = CMD_BUTTON_CHANGE;
//flag for saving data
void saveConfigCallback () {
  shouldSaveConfig = true;
void toggle() {
  Serial.println("toggle state");
  Serial.println(relayState);
  relayState = relayState == HIGH ? LOW : HIGH;
void restart() {
  ESP.reset();
void reset() {
  //reset settings to defaults
    WMSettings defaults;
    settings = defaults;
    EEPROM.begin(512);
    EEPROM.put(0, settings);
    EEPROM.end();
  //reset wifi credentials
  WiFi.disconnect();
  ESP.reset();
//off - button
BLYNK_WRITE(0) {
  int a = param.asInt();
  if (a != 0) {
   turnOff();
//on - button
BLYNK_WRITE(1) {
  if (a != 0) {
    turnOn();
//toggle - button
BLYNK_WRITE(2) {
  if (a != 0) {
    toggle();
//restart - button
BLYNK_WRITE(3) {
  if (a != 0) {
    restart();
//restart - button
BLYNK_WRITE(4) {
  if (a != 0) {
    reset();
//status - display
BLYNK_READ(5) {
  Blynk.virtualWrite(5, relayState);
BLYNK_WRITE(6) {
//EEPROM.begin(100);
  if (a != 0) {
   digitalWrite(D0,LOW);
 // EEPROM.write(0, 0);
     digitalWrite(D0,HIGH);
  //  EEPROM.write(0, 1);
 //EEPROM.commit();
  if (digitalRead(D0)==LOW)
      led1.on();
    led1.off();
BLYNK_WRITE(7) {
  if (a != 0) {
  digitalWrite(D2,LOW);
 //EEPROM.write(1, 0);
      digitalWrite(D2,HIGH);
    //  EEPROM.write(1, 1);
// EEPROM.commit();
  if (digitalRead(D2)==LOW)
      led2.on();
    led2.off();
BLYNK_WRITE(8) {
// EEPROM.begin(100);
  if (a != 0) {
   digitalWrite(D4,LOW);
  // EEPROM.write(2, 0);
     digitalWrite(D4,HIGH);
   //  EEPROM.write(2, 1);
//EEPROM.commit();
  if (digitalRead(D4)==LOW)
      led3.on();
    led3.off();
BLYNK_WRITE(9) {
  if (a != 0) {
   digitalWrite(D5,LOW);
  //EEPROM.write(3, 0);
    led4.on();
     digitalWrite(D5,HIGH);
    //EEPROM.write(3, 1);
     led4.off();
 //EEPROM.commit();
  //set led pin as output
  pinMode(SONOFF_LED, OUTPUT);
    pinMode(D0, OUTPUT);
    pinMode(D2, OUTPUT);
    pinMode(D4, OUTPUT);
    pinMode(D5, OUTPUT);
       led1.off();
       led2.off();
       led3.off();
       led4.off();
  // start ticker with 0.5 because we start in AP mode and try to connect
  ticker.attach(0.6, tick);
  const char *hostname = "SMILE SERVER";
  //set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode
  wifiManager.setAPCallback(configModeCallback);
  //timeout - this will quit WiFiManager if it's not configured in 3 minutes, causing a restart
  wifiManager.setConfigPortalTimeout(180);
  //custom params
  EEPROM.begin(512);
  EEPROM.get(0, settings);
  EEPROM.end();
  if (settings.salt != EEPROM_SALT) {
    Serial.println("Invalid settings in EEPROM, trying with defaults");
  Serial.println(settings.blynkToken);
  Serial.println(settings.blynkServer);
  Serial.println(settings.blynkPort);
  WiFiManagerParameter custom_blynk_text("Blynk config. <br/> No token to disable.");
  wifiManager.addParameter(&custom_blynk_text);
  WiFiManagerParameter custom_blynk_token("blynk-token", "blynk token", settings.blynkToken, 33);
  WiFiManagerParameter custom_blynk_server("blynk-server", "blynk server", settings.blynkServer, 33);
  wifiManager.addParameter(&custom_blynk_server);
  WiFiManagerParameter custom_blynk_port("blynk-port", "blynk port", settings.blynkPort, 6);
  wifiManager.addParameter(&custom_blynk_port);
  if (!wifiManager.autoConnect(hostname)) {
    ESP.reset();
  //Serial.println(custom_blynk_token.getValue());
  if (shouldSaveConfig) {
    Serial.println("Saving config");
    strcpy(settings.blynkToken, custom_blynk_token.getValue());
    strcpy(settings.blynkServer, custom_blynk_server.getValue());
    strcpy(settings.blynkPort, custom_blynk_port.getValue());
    EEPROM.begin(512);
    EEPROM.end();
  //config blynk
  if (strlen(settings.blynkToken) == 0) {
    BLYNK_ENABLED = false;
  if (BLYNK_ENABLED) {
    Blynk.config(settings.blynkToken, settings.blynkServer, atoi(settings.blynkPort));
  //OTA
  ArduinoOTA.onStart([]() {
    Serial.println("Start OTA");
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.setHostname(hostname);
  ArduinoOTA.begin();
  //if you get here you have connected to the WiFi
  Serial.println("connected...Smile :)");
  ticker.detach();
  //setup button
  pinMode(SONOFF_BUTTON, INPUT);
  attachInterrupt(SONOFF_BUTTON, toggleState, CHANGE);
  //setup relay
  pinMode(SONOFF_RELAY, OUTPUT);
  turnOn();
  Serial.println("done setup");
  //ota loop
  ArduinoOTA.handle();
  //blynk connect and run loop
    long duration1 = millis() - startPress1;
      if (duration1 > 2000)
       if (buttonState1==LOW)
             led5.on();
             buttonState1=HIGH;
           led5.off();
            buttonState1=LOW;
        Status();
        startPress1= millis();
 int currentState = digitalRead(SONOFF_BUTTON);
 if (currentState == LOW)
  long duration = millis() - startPress;
  if (duration > 5000)
        reset();
   startPress = millis();
อธิบายเพิ่มหน่อยว่าอัพโหลดไม่ได้หรือว่า อัพได้แต่ไม่ทำงาน
อัพได้ครับ แต่ไม่ทำงาน
แคป serial มาดูครับ
อะไรผิดพลาดไปหรือครับ
เรียบร้อยแล้วครับ ลงไลบารี่ ใหม่ เวอร์ชั่นต่ำลง
เยี่ยมมากครับ อยากทราบว่าดาวน์เกรดลงมาเป็น version ไหน
