ขึ้น Failed to read from DHT sensor! แก้ไงครับ
//Viral science www.youtube.com/c/viralscience
//Temperature sensor
 * Blynk is a platform with iOS and Android apps to control
 * Arduino, Raspberry Pi and the likes over the Internet.
 * You can easily build graphic interfaces for all your
 * projects by simply dragging and dropping widgets.
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * Blynk library is licensed under MIT license
 * This example code is in public domain.
 * This example shows how value can be pushed from Arduino to
 * the Blynk App.
 * WARNING :
 * For this example you'll need SimpleTimer library:
 *   https://github.com/jfturcot/SimpleTimer
 * and Adafruit DHT sensor library:
 *   https://github.com/adafruit/DHT-sensor-library
 * App project setup:
 *   Value Display widget attached to V5
 *   Value Display widget attached to V6
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <SPI.h>
char auth[] = "IYmBv3jknwj2Xhhxhqz1h5bnn6nc_PMB"; //Enter the Auth code which was send by Blink
char ssid[] = "ArmWIFI_2.4G";  //Enter your WIFI Name
char pass[] = "0616612641";  //Enter your WIFI Password
#define DHTPIN 2          // Digital pin 4
// Uncomment whatever type you're using!
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void sendSensor()
  Blynk.virtualWrite(V5, h);  //V5 is for Humidity
  Blynk.virtualWrite(V6, t);  //V6 is for Temperature
  Serial.begin(9600); // See the connection status in Serial Monitor
  Blynk.run(); // Initiates Blynk
  timer.run(); // Initiates SimpleTimer
ถ่ายรูปการต่อมาดูด้วยครับ
