อัพโหลดลงบอร์ดnode mcu v3 esp8266ไม่ได้ครับ ช่วยทีครับ
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM   : 353280          - code in flash         (default or ICACHE_FLASH_ATTR)
IRAM   : 27324   / 32768 - code in IRAM          (ICACHE_RAM_ATTR, ISRs...)
DATA   : 1252  )         - initialized variables (global, static) in RAM/HEAP
RODATA : 1636  ) / 81920 - constants             (global, static) in RAM/HEAP
BSS    : 25016 )         - zeroed variables      (global, static) in RAM/HEAP
Sketch uses 383492 bytes (36%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27904 bytes (34%) of dynamic memory, leaving 54016 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM4
Connecting...
Traceback (most recent call last):
  File "C:\Users\mike\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in <module>
    esptool.main(cmdline)
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
    esp.connect(args.before)
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 475, in connect
    last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 455, in _connect_attempt
    self.sync()
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 394, in sync
    timeout=SYNC_TIMEOUT)
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 337, in command
    self.write(pkt)
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 300, in write
    self._port.write(buf)
  File "C:/Users/mike/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/pyserial\serial\serialwin32.py", line 323, in write
    raise writeTimeoutError
serial.serialutil.SerialTimeoutException: Write timeout
the selected serial port serial.serialutil.SerialTimeoutException: Write timeout
 does not exist or your board is not connected
ก่อนหน้านี้ สามารถ Up Code กับ Board อื่นได้ปกติไหม
ก่อนหน้านี้ตอนเรียนอัพไดัปกติครับ แต่ตอนนั้นประมาณ7เดือนที่แล้วครับ
เข้าไป update Library และ Ver. Board ก่อนครับ มีการ Up Date อุปกรณ์ และ Library
ผมลองอัพเดตหมดแล้วก็ยังเหมือนเดิมครับ
ใช้ Board ของอะไรครับ
รบกวน ขอดู Code หน่อยครับ
เลือก Board อะไรไว้ครับ ขอดูการเลือก Board ตามตัวอย่างหน่อยครับ
#define WIFI_SSID "3BB_Thawatchai_2.4GHz" /////////////*************แก้
#define WIFI_PASSWORD "0811918302"////////**************แก้
#define LINE_TOKEN_PIR "cluGT37AqLdQzGiyXLUZk2ZyLL4L5rmqHRzvf8CCrn2" ////***************แก้
#define PirPin 12
String message1 = "%E0%B9%84%E0%B8%94%E0%B9%89%E0%B8%A3%E0%B8%B1%E0%B8%9A%E0%B8%88%E0%B8%94%E0%B8%AB%E0%B8%A1%E0%B8%B2%E0%B8%A2%E0%B9%81%E0%B8%A5%E0%B9%89%E0%B8%A7";//****************แก้
bool beep_state = false;
bool send_state = false;
uint32_t ts, ts1, ts2;
  pinMode(PirPin, INPUT);
  pinMode(LED_BUILTIN, OUTPUT);
 // dht.begin();
  Serial.println("connecting");
  WiFi.mode(WIFI_STA);
  Serial.print("connecting");
  Serial.print("connected: ");
  delay(10000);
  //read_sensor();
  ts = ts1 = ts2 = millis();
  ts = millis();
    beep_state = false;
    Serial.println("Detect !");
    Line_Notify1(message1);
    beep_state = true;
  WiFiClientSecure client;
  String req = "";
  req += "\r\n";
  req += "message=" + message1;
  // Serial.println(req);
  while (client.connected()) {
    if (line == "\r") {
Code เขียนเองหรือ Copy จาก Net แล้วเอามาวางครับ
ตอนนี้ Code การแจ้งเข้า Line มี Library ตัวใหม่ เขียนง่ายมากแล้วครับ
copy จากในเว็บครับ
ทดลองที่ละขั้นนะครับ
  1. กดเครื่องหมายถูก ตรงมุมซ้ายบนก่อน ตรงนั้นจะเป็นการตรวจสอบ Code ว่าเขียนได้ถูกต้องไหม ถ้าถูกต้อง จะต้องไม่มีการแจ้งเตือน แต่ถ้า error copy ทั้งหน้าให้ดูหน่อย จะมีเส้นสีส้มๆแจ้งเตือนบรรทัดไหน error แล้วดูว่า แจ้งเตือนอะไร
ดังตัวอย่าง Code ของท่านที่ส่งมามันมี Error อยู่ สาเหตุจากการ Copy มาจากเนท แล้วเครื่องหมายฟันหนู ( " " ) มันไม่ถูกต้อง ต้องใช้เครื่องหมายฟันหนู ของ Front ของเครื่องเรา
Front ของเครื่องเรา
Code ของท่านที่แก้ไข ฟันหนู โดยใช้ Front ของเครื่องที่ติดตั้ง IDE ไว้ สามารถ compile ผ่าน
ได้แล้วครับ ขอบคุณครับ
สรุปให้หน่อยครับ ทำยังไงถึงสามารถแก้ปัญหาได้ จะได้เป็นข้อมูลให้กับท่านอื่นๆ ได้ทำตามเพื่อแก้ไขปัญหาเดียวกันได้ครับ
