ขอดูโค้ตที่ใช้ครับ
ใช่คับส่งค่ามาที่blynk คับ
pzem
- List item
เปิดในโทรศัพไม่ได้เดียวช่วงเย็นเดียวเอามาลงให้นะคับ
โอเคครับ
#include <PZEM004T.h>
#include <ThingspeakClient.h>
#define FIRST_ADDRESS 0
#define MAX_ATTEMPTS 10
#define min(a,b) ((a)<(b)?(a):(b))
PZEM004T pzem(4, 5); // RX,TX d2,d6
IPAddress ip(192, 168, 1, 1);
const char* ssid = "tanawat";
const char* password = "Wat08076677433";
char auth[] = "xFBNngkpA5dvh5MTWhygWS1hnCbCZEUV"; //Blynk Token
WiFiClient client;
ThingspeakClient thingspeak;
const char* host = "api.thingspeak.com";
const String THINGSPEAK_CHANNEL_ID = "860804";
const String THINGSPEAK_API_READ_KEY = "2IXSQKX4AN4LDH0P"; //read key
const char* api = "AQDT0NYNL3U1W7YI"; //write key
float v, i, p, e, b;
long milisec = 0;
float calBill(float Unit, float ft, bool over_150_Unit_per_month = false) ;
float FT = -15.9;
int firstState;
void Line_Notify(String message);
int token = 0;
String LINE_TOKEN[2] = {"n1vN3fQAUMQRhGdMdijqQYUyiopmm3sYxfyCBeIsRkJ", "sUS5V77H0wOMyXjHudqGsdaUCwO3EFCPeGW9nJl8WhX"}; //line token
unsigned long currentMillis, previousMillis, previousMillis2, previousMillis3, readMillis = 0;
String message = "%20Volt%20"; // " Volt "
String message2 = "%20Current%20"; // " Current "
String message3 = "%20Power%20Now%20"; // " Power Now "
String message4 = "%20Energy%20"; // " Energy "
String message5 = "%20Cost%20"; // " Cost "
String message6 = "%20Warning%20overload%20"; // " Warning overload "
String message7 = "%20Power%20Total%20"; // " Power Total "
pzem.setAddress(ip);
EEPROM.begin(512);
firstState = EEPROM.read(FIRST_ADDRESS);
Serial.println(firstState);
if (firstState == 5) {
Serial.print("use again:");
thingspeak.getLastChannelItem(THINGSPEAK_CHANNEL_ID, THINGSPEAK_API_READ_KEY);
String f1 = (thingspeak.getFieldValue(3));
String f2 = (thingspeak.getFieldValue(4));
String f3 = (thingspeak.getFieldValue(5));
e = f1.toFloat();
b = f2.toFloat();
FT = f3.toFloat();
Serial.print("use new:");
Serial.println("first write eeprom");
EEPROM.write(0, 5);
EEPROM.commit();
ReadPzem();
SendNormal();
currentMillis = previousMillis = previousMillis2 = previousMillis3 = readMillis = millis();
Serial.println(FT);
Blynk.virtualWrite(V7, FT);
b = calBill(e, FT, true);
currentMillis = millis();
if (currentMillis - readMillis >= 1000) {
ReadPzem();
SetBlynk();
if (currentMillis - previousMillis3 >= 30000) UpdateThingspeak();
if (currentMillis - previousMillis >= 900000) SendNormal();
if (i >= 2.00 && currentMillis - previousMillis2 >= 60000) SendWarning();
void ReadPzem() {
unsigned long time;
v = getVoltage();
i = getCurrent();
p = v * i;
if (p >= 1) {
time += 1;
e += (p * time) / (1000 * 3600);
time = 0;
Serial.print("Volt: "); Serial.print(v); Serial.print("V\n");
Serial.print("Current: "); Serial.print(i); Serial.print("A\n");
Serial.print("power Now: "); Serial.print(p); Serial.print("W\n");
Serial.print("Energy: "); Serial.print(e, 3); Serial.print("kWh\n");
Serial.print("Cost: "); Serial.print(b, 3); Serial.print("฿\n");
Serial.print("FT: "); Serial.println(FT);
Serial.println("--------------------");
void SetBlynk() {
Blynk.virtualWrite(V0, v);
Blynk.virtualWrite(V1, i);
Blynk.virtualWrite(V2, p);
Blynk.virtualWrite(V4, e);
Blynk.virtualWrite(V5, b);
Blynk.virtualWrite(V6, FT);
void UpdateThingspeak() {
previousMillis3 = millis();
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
String etemp = String(e, 3);
String btemp = String(b, 3);
// We now create a URI for the request
String url = "/update?api_key=";
url += api;
url += "&field1=";
url += v;
url += "&field2=";
url += i;
url += "&field3=";
url += p;
url += "&field4=";
url += etemp;
url += "&field5=";
url += btemp;
url += "&field6=";
url += FT;
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
// Read all the lines of the reply from server and print them to Serial
while (client.available()) {
Serial.print(line);
void SendNormal() {
previousMillis = millis();
token = 0;
Line_Notify(message + v + "V" + message2 + i + "A" + message3
+ p + "W" + message4 + e + "Wh" + message5 + b + "฿");
void SendWarning() {
previousMillis2 = millis();
token = 1;
Line_Notify(message6 + i + "A");
BLYNK_WRITE(V7) {
FT = param[0].asFloat();
BLYNK_WRITE(V8) {
p = 0.0;
e = 0.0;
b = 0.0;
float calBill(float Unit, float ft, bool over_150_Unit_per_month) {
float Service = over_150_Unit_per_month ? 38.22 : 8.19;
float total = 0;
if (!over_150_Unit_per_month) {
float Rate15 = 2.3488;
float Rate25 = 2.9882;
float Rate35 = 3.2405;
float Rate100 = 3.6237;
float Rate150 = 3.7171;
float Rate400 = 4.2218;
float RateMore400 = 4.4217;
if (Unit >= 6) total += min(Unit, 15) * Rate15;
if (Unit >= 16) total += min(Unit - 15, 10) * Rate25;
if (Unit >= 26) total += min(Unit - 25, 10) * Rate35;
if (Unit >= 36) total += min(Unit - 35, 65) * Rate100;
if (Unit >= 101) total += min(Unit - 100, 50) * Rate150;
if (Unit >= 151) total += min(Unit - 150, 250) * Rate400;
if (Unit >= 401) total += (Unit - 400) * RateMore400;
float Rate150 = 3.2484;
total += min(Unit, 150) * Rate150;
total += Service;
total += Unit * (ft / 100);
total += total * 7 / 100;
return total;
WiFiClientSecure client;
String req = "";
req += "Authorization: Bearer " + String(LINE_TOKEN[token]) + "\r\n";
req += "\r\n";
req += "message=" + message;
delay(30);
while (client.connected()) {
if (line == "\r") {
float getVoltage() {
int i = 0;
float r = -1.0;
do {
r = pzem.voltage(ip);
wdt_reset();
i++;
} while ( i < MAX_ATTEMPTS && r < 0.0);
return r;
float getCurrent() {
int i = 0;
float r = -1.0;
do {
r = pzem.current(ip);
wdt_reset();
i++;
return r;
-1คับ:expressionless:
หมายถึง Serial.print จาก Arduino IDE ครับ
จะเห็นได้ว่าค่า Volt และ Current ได้ -1 ทั้งคู่แสดงว่าที่ blynk และ websocket นั้นแสดงค่าถูกแล้ว ลองเช็ค Hardware ดูก่อนว่าได้ค่าจริงๆ ก่อนเข้าไปในบอร์ดเท่าไหร่ ครับ ตรงกันรึป่าว
อีกคำถามคือต่อ Hardware แบบไหน?
เช็คให้ดีครับ เอาอะไรวัดก่อนเข้าบอร์ดก็ได้ ยืนยันว่า Hardware เราไม่ได้ผิด ไม่งั้นเข้าไปงมโค้ตตายเลยทีนี้
ลองเช็คแล้วมาอัพเดทหน่อยนะครับ
