Esp32 เชื่อม wifi ได้แล้ว แต่ใน Blynk ขึ้นสถานะเป็น ออฟไลน์ครับ
  You’ll need:
   - Blynk IoT app (download from App Store or Google Play)
   - ESP32 board
   - Decide how to connect to Blynk
     (USB, Ethernet, Wi-Fi, Bluetooth, ...)
  There is a bunch of great example sketches included to show you how to get
  started. Think of them as LEGO bricks  and combine them as you wish.
  For example, take the Ethernet Shield sketch and combine it with the
  Servo example, or choose a USB sketch and add a code from SendData
  example.
// Template ID, Device Name and Auth Token are provided by the Blynk.Cloud
// See the Device Info tab, or Template settings
#define BLYNK_TEMPLATE_ID           "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME           "Device"
#define BLYNK_AUTH_TOKEN            "YourAuthToken"
// Comment this out to disable prints and save space
char auth[] = "MVu2T5OaUxLRUOj3ijBdy8uh3vKRMMus";
char ssid[] = "Esp32";
char pass[] = "zzzzzzzz";
  //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
  // to avoid delay() function!
