const int Relay = 5;
const int analogInPin = A0;
int sensorValue = 0; // ตัวแปรค่า Analog
char auth[] = "xSgDj9NPgBkeLZ7HqqUxbrRqwjrLcvaa";
char ssid[] = "PUYZI";
char pass[] = "20102525";
// You'll get HIGH/1 at startTime and LOW/0 at stopTime.
// this method will be triggered every day
// until you remove widget or stop project or
// clean stop/start fields of widget
Serial.print("Got a value: ");
if(param.asInt() == 0)
digitalWrite(Relay, LOW);
if(param.asInt() == 1)
digitalWrite(Relay, HIGH);
pinMode(Relay,OUTPUT);
outputValue = map(sensorValue, 0, 1023, 100, 0);
Blynk.virtualWrite(V83, outputValue);
Serial.print("Soil Moisture = ");
Serial.print(outputValue);
Serial.println(" %");
Soil Moisture ใช้ตัวไหนต้องเอามาดูครับ
