upcode arduino_push_keypad_2_digits
diff --git a/Arduino/arduino_push_keypad_2_digits/.vscode/arduino.json b/Arduino/arduino_push_keypad_2_digits/.vscode/arduino.json
new file mode 100644
index 0000000..c3d82de
--- /dev/null
+++ b/Arduino/arduino_push_keypad_2_digits/.vscode/arduino.json
@@ -0,0 +1,5 @@
+    "board": "arduino:avr:uno",
+    "sketch": "arduino_push_keypad_2_digits.ino",
+    "port": "COM16"
\ No newline at end of file
diff --git a/Arduino/arduino_push_keypad_2_digits/.vscode/c_cpp_properties.json b/Arduino/arduino_push_keypad_2_digits/.vscode/c_cpp_properties.json
index 0000000..3efc096
--- /dev/null
+++ b/Arduino/arduino_push_keypad_2_digits/.vscode/c_cpp_properties.json
@@ -0,0 +1,19 @@
+    "configurations": [
+            "name": "Win32",
+            "includePath": [
+                "C:\\Users\\ArcHeR\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\**",
+                "C:\\Users\\ArcHeR\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\**"
+            "forcedInclude": [
+                "C:\\Users\\ArcHeR\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Arduino.h"
+            "intelliSenseMode": "msvc-x64",
+            "compilerPath": "C:\\Program Files (x86)\\mingw-w64\\i686-8.1.0-posix-dwarf-rt_v6-rev0\\mingw32\\bin\\gcc.exe",
+            "cStandard": "c11",
+            "cppStandard": "gnu++14"
+    "version": 4
diff --git a/Arduino/arduino_push_keypad_2_digits/arduino_push_keypad_2_digits.ino b/Arduino/arduino_push_keypad_2_digits/arduino_push_keypad_2_digits.ino
index 0000000..cd336b0
--- /dev/null
+++ b/Arduino/arduino_push_keypad_2_digits/arduino_push_keypad_2_digits.ino
@@ -0,0 +1,104 @@
+#include <Keypad.h>
+float xxx;
+unsigned long pwm1;
+const byte ROWS = 4; //four rows
+const byte COLS = 3; //three columns
+int inputA1;
+char keys[ROWS][COLS] = {
+  {'1','2','3'},
+  {'4','5','6'},
+  {'7','8','9'},
+  {'*','0','#'}
+byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
+byte colPins[COLS] = {4, 3, 2}; //connect to the column pinouts of the keypad
+//Create an object of keypad
+Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
+void setup(){
+  pinMode(9, OUTPUT);
+TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(COM1B0) | _BV(WGM11);
+TCCR1B = _BV(WGM13) | _BV(CS11);
+  Serial.begin(9600);
+char key;
+int ckey = 0;
+void loop(){
+  key = keypad.getKey();// Read the key
+if (key != NO_KEY)
+Serial.println(key);
+if(ckey == 2){
+  if(key == '0'){ //เมื่อ กด 0 เข้าเงื่อนไขนี้
+      inputA1 = 1024; // แทนค่า inputA1 ด้วย 1024 ที่ทำให้ PWM มี dutycycle 5 %
+      Serial.println(String("Read inputA1 = ")+ inputA1);
+  if(key == '1'){ //เมื่อ กด 1 เข้าเงื่อนไขนี้
+      inputA1 = 900; // แทนค่า inputA1 ด้วย 900 ที่ทำให้ PWM มี dutycycle 10 %
+  if(key == '2'){ //เมื่อ กด 2 เข้าเงื่อนไขนี้
+      inputA1 = 800; // แทนค่า inputA1 ด้วย 800 ที่ทำให้ PWM มี dutycycle 15 %
+  if(key == '3'){ //เมื่อ กด 3 เข้าเงื่อนไขนี้
+      inputA1 = 700; // แทนค่า inputA1 ด้วย 700 ที่ทำให้ PWM มี dutycycle 20 %
+  if(key == '4'){ //เมื่อ กด 4 เข้าเงื่อนไขนี้
+      inputA1 = 600; // แทนค่า inputA1 ด้วย 600 ที่ทำให้ PWM มี dutycycle 30 %
+  if(key == '5'){ //เมื่อ กด 5 เข้าเงื่อนไขนี้
+      inputA1 = 500; // แทนค่า inputA1 ด้วย 500 ที่ทำให้ PWM มี dutycycle 40 %
+  if(key == '6'){ //เมื่อ กด 6 เข้าเงื่อนไขนี้
+      inputA1 = 400; // แทนค่า inputA1 ด้วย 400 ที่ทำให้ PWM มี dutycycle 50 %
+  if(key == '7'){ //เมื่อ กด 7 เข้าเงื่อนไขนี้
+      inputA1 = 300; // แทนค่า inputA1 ด้วย 300 ที่ทำให้ PWM มี dutycycle 60 %
+  if(key == '8'){ //เมื่อ กด 8 เข้าเงื่อนไขนี้
+      inputA1 = 200; // แทนค่า inputA1 ด้วย 200 ที่ทำให้ PWM มี dutycycle 70 %
+  if(key == '9'){ //เมื่อ กด 9 เข้าเงื่อนไขนี้
+      inputA1 = 100; // แทนค่า inputA1 ด้วย 100 ที่ทำให้ PWM มี dutycycle 80 %
+  if(key == '*'){ //เมื่อ กด * เข้าเงื่อนไขนี้
+      inputA1 = 50; // แทนค่า inputA1 ด้วย 50 ที่ทำให้ PWM มี dutycycle 90 %
+  if(key == '#'){ //เมื่อ กด # เข้าเงื่อนไขนี้
+      inputA1 = 0; // แทนค่า inputA1 ด้วย 0 ที่ทำให้ PWM มี dutycycle 100 %
+ ICR1 = 62.5;
+pwm1 = inputA1;
+xxx = float(pwm1);
+xxx = xxx * ICR1;
+xxx = xxx / 512;
+OCR1A = int(62.5-(xxx/2));
diff --git a/Arduino/arduino_push_keypad_pwm/.vscode/c_cpp_properties.json b/Arduino/arduino_push_keypad_pwm/.vscode/c_cpp_properties.json
index 46e7bc8..a0d4f47 100644
--- a/Arduino/arduino_push_keypad_pwm/.vscode/c_cpp_properties.json
+++ b/Arduino/arduino_push_keypad_pwm/.vscode/c_cpp_properties.json
@@ -4,10 +4,12 @@
             "name": "Win32",
             "includePath": [
                 "C:\\Program Files (x86)\\Arduino\\tools\\**",
-                "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\**"
+                "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\**",
+                "C:\\Users\\ArcHeR\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\**",
             "forcedInclude": [
-                "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Arduino.h"
GitHub
sha: fc816f42
