Water Flow Sensor วัดอัตราการไหลของน้ำ
สมาชิกท่านไหน พอมี code เซนเซอร์วัดอัตราการไหลของน้ำที่ใช้กับ esp8266 บ้างไหมคับ
YF-S201C Water Flow Sensor
ตัวนี้คับ
ตัวที่มีใช้ไฟกี่โวลต์ครับ
มองไม่ชัด ถ่ายป้ายชัดๆ มาดูหน่อย นี้ตัวอย่างสำหรับ 9V
int Pulses = 3;          //Arduino digital pin 3 is declared as Pulses
int led    = 7; //Led pin
volatile int pulsecount; //Variable to count number of pulses
volatile int i=0;                 //Variable for led status
  //Interrupt pin 3 declared as input and pull up resitor is enabled
  pinMode(Pulses, INPUT_PULLUP);
  //Led as output
  pinMode(led, OUTPUT);
  //Interrupt is attached to pin 3
  //ISR(interuupt service routine) of interrupt is CountPulses
  //Interrupt is activated on HIGH to LOW transition
  attachInterrupt(digitalPinToInterrupt(Pulses), CountPulses, FALLING);
  Serial.begin(9600);  //Starting serial monitor
  pulsecount = 0;  //Start counting from 0 again
  i=0;             //Reset led toggling variable
  interrupts();    //Enables interrupt on arduino pin 3
  delay (1000);    //Wait 1 second
  noInterrupts();  //Disable the interrupt
 //One second is over now and we have the number of pulses in variable
 //'pulsecount'
 //Calculating the water flow rate in Milli Liters per minute
  double flowRate;
  flowRate = (pulsecount * 2.22 * 60);
  Serial.print("Flow rate=");
  Serial.print(flowRate);   //Print milli liters per minute on serial monitor
  Serial.println("mL/minute");
void CountPulses()
    pulsecount++; //Increment the variable on every pulse
    //On every pulse toggle the state of led.
    if(i%2==0)
    digitalWrite(led,HIGH);
    digitalWrite(led,LOW);
    i++;
สำหรับ ESP8266
YF-S201C Water Flow Sensor + esp8266
Code Example
#include <Arduino.h>
#define USE_SERIAL Serial
  // Variable init
  const int  buttonPin = D2; // variable for D2 pin
  int contagem = 0;   // variable to store the “rise ups” from the flowmeter pulses
  int litros = 0;
  char litros_string[10]="0";
  int addr = 0; //endereço eeprom
  //SSID and PASSWORD for the AP (swap the XXXXX for real ssid and password )
  const char* ssid = "XXXXX";
  const char* password = "XXXXX";
  //Interrupt function, so that the counting of pulse “rise ups” dont interfere with the rest of the code  (attachInterrupt)
  void pin_ISR()
      contagem++;
   // Serial Comunication init
   // EEPROM access init
   EEPROM.begin(1);
   litros=EEPROM.read(addr);
   // Initialization of the variable “buttonPin” as INPUT (D2 pin)
   pinMode(buttonPin, INPUT);
   // Wifi connection init
   Serial.print("A iniciar ligação...");
   WiFi.begin(ssid, password);
  //Waiting for the connection to be established
   Serial.print("Waiting for the connection...");
      if(WiFi.status() == WL_CONNECTED)
        Serial.printf("Connect to the SSID: %s",ssid);
  // Attach an interrupt to the ISR vector
  attachInterrupt(digitalPinToInterrupt(buttonPin), pin_ISR, RISING);
  Serial.print("Waiting for client....");
  if(contagem > 440 )
      litros++;
      Serial.print("Litros: ");
      Serial.print(litros);
      //Write the new litres value to the EEPROM and put “contagem” variable to zero
      EEPROM.write(addr, litros);
      EEPROM.commit();
      contagem = 0;
  }//stop counting
