const int buttonPin1 = 2; // the number of the pushbutton pin
const int buttonPin2 = A2; // the number of the pushbutton pin
int buttonState1 = 0;
int buttonState2 = 0;
int digit1 = 11; //PWM Display pin 1
int digit2 = 10; //PWM Display pin 2
int digit3 = 9; //PWM Display pin 6
int digit4 = 6; //PWM Display pin 8
int segA = A1; //Display pin 14
int segB = 3; //Display pin 16
int segC = 4; //Display pin 13
int segD = 5; //Display pin 3
int segE = A0; //Display pin 5
int segF = 7; //Display pin 11
int segG = 8; //Display pin 15
int numberToDisplay;
int data2;
int a = 1;
int b = 0;
unsigned int buff1,buff2,buff3,buff4,temp;
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
#define DIGIT_ON LOW
#define DIGIT_OFF HIGH
#define SEGMENT_ON HIGH
#define SEGMENT_OFF LOW
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
if (buttonState1 == HIGH){
delay(700);
b=a++;
if (buttonState2 == HIGH){
delay(700);
b=0;
a=1;
data2=b;
buff1=(data2/1000);
temp=(data2%1000);
buff2=(temp/100);
temp=temp%100;
buff3=(temp/10);
buff4=(temp%10);
numberToDisplay=buff1;
switch (numberToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
case 3:
case 4:
case 5:
digitalWrite(segB, SEGMENT_OFF);
case 6:
case 7:
case 8:
case 9:
case 10:
if (data2 > 999){
digitalWrite(digit1, DIGIT_ON);
delay(1);
digitalWrite(digit1, DIGIT_OFF);
delay(1);
numberToDisplay=buff2;
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
if(data2 > 99){
digitalWrite(digit2, DIGIT_ON);
delay(1);
digitalWrite(digit2, DIGIT_OFF);
delay(1);
numberToDisplay=buff3;
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
if(data2 > 9){
digitalWrite(digit3, DIGIT_ON);
delay(1);
digitalWrite(digit3, DIGIT_OFF);
delay(1);
numberToDisplay=buff4;
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
if(data2 > 0){
digitalWrite(digit4, DIGIT_ON);
delay(1);
digitalWrite(digit4, DIGIT_OFF);
delay(1);
