อยากตั้งเวลา เปิด-ปิด รีเลย์ 1 และ กำหนดค่าอุณหภูมิให้ทำงานAuto โดยปรับผ่านหน้าจอ app netpie
รบกวนทุกท่านช่วยชี้แนะ ว่าต้อง แก้ตรงไหน ครับ
#include <PubSubClient.h>
int ddht = 14; //D5
#define DHTTYPE DHT11
DHT dht(ddht, DHTTYPE);
int relay1 =  2 ; // D4
int relay2 = 16 ; // D0
int relay3 = 12 ; // D6
int relay4 = 13 ; // D7
String autoHum = "on";
String autoTem = "on";
String SW01 = "on";
String SW02 = "on";
const char* ssid = "XXXXXXXXXXXXXXXXXX";
const char* password = "XXXXXXXXXXXXXXXXXX";
const char* mqtt_server = "broker.netpie.io";
const int mqtt_port = 1883;
const char* mqtt_Client = "XXXXXXXXXXXXXXXXXX";
const char* mqtt_username = "XXXXXXXXXXXXXXXXXX";
const char* mqtt_password = "AXXXXXXXXXXXXXXXXXX";
WiFiClient espClient;
PubSubClient client(espClient);
char msg[100];
void reconnect() {
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection…");
    if (client.connect(mqtt_Client, mqtt_username, mqtt_password)) {
      Serial.println("connected");
      client.subscribe("@msg/#");
      client.subscribe("@msg/relay2");    //////////////////////////////////////////////
      client.subscribe("@msg/relay3");
      client.subscribe("@msg/relay4");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println("try again in 5 seconds");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  String message;
  String tpc;
  for (int i = 0; i < length; i++) {
    message = message + (char)payload[i];
  Serial.println(message);
  if (String(topic) == "@msg/relay1") {
    if(message == "on"){
      digitalWrite(relay1,LOW);
      client.publish("shadow/data/updata","(\"data\":(\"relay1\":\"on\"))");
      Serial.println("relay1 ON");}
    else  if(message == "off"){
      digitalWrite(relay1,HIGH);
      client.publish("shadow/data/updata","(\"data\":(\"relay1\":\"off\"))");
      Serial.println("relay1 OFF");}
  if (String(topic) == "@msg/relay2") {
      digitalWrite(relay2,LOW);
      client.publish("shadow/data/updata","(\"data\":(\"relay2\":\"on\"))");
      Serial.println("relay2 ON");}
      digitalWrite(relay2,HIGH);
      client.publish("shadow/data/updata","(\"data\":(\"relay2\":\"off\"))");
      Serial.println("relay2 OFF");}
  if (String(topic) == "@msg/relay3") {
      digitalWrite(relay3,LOW);
      client.publish("shadow/data/updata","(\"data\":(\"relay3\":\"on\"))");
      Serial.println("relay3 ON");}
      digitalWrite(relay3,HIGH);
      client.publish("shadow/data/updata","(\"data\":(\"relay3\":\"off\"))");
      Serial.println("relay3 OFF");}
   if (String(topic) == "@msg/relay4") {
      digitalWrite(relay4,LOW);
      client.publish("shadow/data/updata","(\"data\":(\"relay4\":\"on\"))");
      Serial.println("relay4 ON");}
      digitalWrite(relay4,HIGH);
      client.publish("shadow/data/updata","(\"data\":(\"relay4\":\"off\"))");
      Serial.println("relay4 OFF");}
  dht.begin(14);
  pinMode(relay1, OUTPUT);
  digitalWrite(relay1, HIGH);
  pinMode(relay2, OUTPUT);
  digitalWrite(relay2, HIGH);
  pinMode(relay3, OUTPUT);
  digitalWrite(relay3, HIGH);
  pinMode(relay4, OUTPUT);
  digitalWrite(relay4, HIGH);
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  client.setServer(mqtt_server, mqtt_port);
  client.setCallback(callback);
      if (!client.connected()) {
      reconnect();
    if (isnan(h) || isnan(t))
        Serial.println(F("Failed to read from DHT sensor!"));
  if (autoTem == "on") {
    if (t > 60) {        //ตั้งการแบบปรั้งค่าที่ netpie ได้ ครับ
      digitalWrite(relay1, LOW);
  int r1 = digitalRead(relay1);
  int r2 = digitalRead(relay2);
  int r3 = digitalRead(relay3);
  int r4 = digitalRead(relay4);
//==================เป็นการส่ง data goto netpie======================================
String data = "{\"data\":{\"Humidity\":"+String(h) +
              ",\"Temperature\":"+String(t)+
              ",\"relay1\":"+String(r1)+
              ",\"relay2\":"+String(r2)+
              ",\"relay3\":"+String(r3)+
              ",\"relay4\":"+String(r4)+
  Serial.println(data);
  data.toCharArray(msg , (data.length() + 1));
  client.publish("@shadow/data/update", msg);
  client.loop();
}    //==== end void loop ===============
String getMsg(String topic_, String message_)
    if (topic_ == "@msg/relay1") {
      if (message_ == "on") {        //netpie["???"].publish("@msg/relay1","on")
          autoHum = "off";
     } else if (message_ == "off") { //netpie["???"].publish("@msg/relay1","off")
       autoTem = "on";
     return autoHum;
มือใหม่ครับ รบกวนด้วยครับ ขอบคุณครับ
การตั้งเวลาเปิด-ปิดรีเลย์และการกำหนดค่าอุณหภูมิให้ทำงานแบบอัตโนมัติ โดยปรับผ่านหน้าจอ App NETPIE สามารถทำได้โดยเพิ่มฟังก์ชันการตรวจสอบข้อความจาก MQTT ที่รับค่าต่าง ๆ เช่น เวลาเปิด-ปิดและค่าที่ต้องการให้อุณหภูมิทำงานแบบ Auto จากข้อความที่ส่งมาจาก NETPIE
สิ่งที่ต้องปรับในโค้ด
  1. เพิ่มตัวแปรสำหรับตั้งค่าจาก NETPIE:
  • เพิ่มตัวแปรสำหรับเวลาการทำงานของรีเลย์ (เปิด-ปิด) เช่น startTimeRelay1 และ endTimeRelay1
  • เพิ่มตัวแปรสำหรับอุณหภูมิที่ต้องการ เช่น autoTempThreshold
  1. ปรับฟังก์ชัน callback:
  • เพิ่มการตรวจสอบข้อความที่เกี่ยวข้องกับเวลาการทำงานและอุณหภูมิ
  • อัปเดตค่าตัวแปรตามข้อมูลที่รับจาก NETPIE
  1. ปรับ void loop():
  • เพิ่มเงื่อนไขในการตรวจสอบเวลาเปิด-ปิดของรีเลย์
  • ใช้ค่าที่ตั้งมาจาก MQTT ในการควบคุมรีเลย์
ตัวอย่างโค้ดที่ปรับปรุง
// เพิ่มตัวแปรใหม่
unsigned long startTimeRelay1 = 0; // เวลาเริ่มเปิดรีเลย์ 1 (หน่วย: วินาที)
unsigned long endTimeRelay1 = 86400; // เวลาเปิดรีเลย์ 1 สิ้นสุด (24 ชั่วโมง)
float autoTempThreshold = 30.0; // ค่าอุณหภูมิที่ต้องการ
    String message;
        message += (char)payload[i];
    // ตรวจสอบหัวข้อสำหรับตั้งค่ารีเลย์
    if (String(topic) == "@msg/relay1/start") {
        startTimeRelay1 = message.toInt(); // รับค่าเวลาเริ่มต้น
    } else if (String(topic) == "@msg/relay1/end") {
        endTimeRelay1 = message.toInt(); // รับค่าเวลาสิ้นสุด
    } else if (String(topic) == "@msg/autoTempThreshold") {
        autoTempThreshold = message.toFloat(); // รับค่าอุณหภูมิ
    // โค้ดเดิมสำหรับการควบคุมรีเลย์
        if (message == "on") {
            client.publish("shadow/data/updata", "(\"data\":(\"relay1\":\"on\"))");
        } else if (message == "off") {
            client.publish("shadow/data/updata", "(\"data\":(\"relay1\":\"off\"))");
        reconnect();
    client.loop();
    // อ่านค่าจากเซ็นเซอร์ DHT
    // ตรวจสอบค่าเวลาและอุณหภูมิ
    unsigned long currentTime = millis() / 1000; // เวลาปัจจุบัน (หน่วย: วินาที)
    if (autoTem == "on" && t > autoTempThreshold) {
        digitalWrite(relay1, LOW); // เปิดรีเลย์ถ้าอุณหภูมิเกิน
    } else if (autoTem == "on") {
        if (currentTime >= startTimeRelay1 && currentTime <= endTimeRelay1) {
            digitalWrite(relay1, LOW); // เปิดรีเลย์ตามเวลาที่ตั้ง
            digitalWrite(relay1, HIGH); // ปิดรีเลย์ถ้าอยู่นอกเวลาที่ตั้ง
    // ส่งข้อมูลไปยัง NETPIE
    String data = "{\"data\":{\"Humidity\":" + String(h) +
                  ",\"Temperature\":" + String(t) +
                  ",\"relay1\":" + String(digitalRead(relay1)) + "}}";
    client.publish("@shadow/data/update", data.c_str());
สิ่งที่ต้องทำใน App NETPIE
  1. สร้างสไลเดอร์หรือตัวควบคุมเพื่อส่งค่าเวลาเปิด-ปิดรีเลย์ (startTimeRelay1 และ endTimeRelay1) และค่าที่ต้องการสำหรับอุณหภูมิ (autoTempThreshold).
  2. ส่งค่าผ่าน MQTT โดยกำหนดหัวข้อเป็น @msg/relay1/start, @msg/relay1/end, และ @msg/autoTempThreshold.
จุดสำคัญ
  • ตรวจสอบการส่งค่าผ่าน App NETPIE เพื่อให้แน่ใจว่า MQTT หัวข้อและข้อความถูกต้อง
  • ทดสอบระบบอย่างละเอียดเพื่อให้มั่นใจว่าการทำงานสอดคล้องกับเวลาที่กำหนด
คำแนะนำเพิ่มเติม
  • อาจเพิ่มการบันทึกค่า startTimeRelay1, endTimeRelay1 และ autoTempThreshold ลงในหน่วยความจำ EEPROM ของ ESP8266 เพื่อให้ค่าเหล่านี้ยังคงอยู่หลังการรีเซ็ตอุปกรณ์.
