หากผมต้องการเพิ่มค่า sid เป็น 2 เเทรกส่วนไหนหรอครับ
ว่งโค้ตที่ใช้ด้วยครับ
const char* ssid = "Office";
const char* password = "xxxxxdddf";
//Your Domain name with URL path or IP address with path
const char* serverName = "https://jaiangelbot.cc.pcs-plp.com/testbot/wtsensor.php";
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 5 seconds (5000)
unsigned long timerDelay = 5000;
WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println("Timer set to 5 seconds (timerDelay variable), it will take 5 seconds before publishing the first reading.");
//Send an HTTP POST request every 10 minutes
if ((millis() - lastTime) > timerDelay) {
//Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, serverName);
// Specify content-type header
// http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Data to send with HTTP POST
// String httpRequestData = "sid=1&api_key=xxxxxx&light=1100&hum=120&time=20220615113712&type=alert";
// Send HTTP POST request
//int httpResponseCode = http.POST(httpRequestData);
// If you need an HTTP request with a content type: application/json, use the following:
http.addHeader("Content-Type", "application/json");
int httpResponseCode = http.POST("{\"sid\":\"1\",\"api_key\":\"xxxxxx\",\"light\":\"1000\",\"hum\":\"120\",\"time\":\"20220615113712\",\"type\":\"alert\"}");
// If you need an HTTP request with a content type: text/plain
//http.addHeader("Content-Type", "text/plain");
//int httpResponseCode = http.POST("Hello, World!");
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
// Free resources
http.end();
Serial.println("WiFi Disconnected");
lastTime = millis();
ที่ยิงขึ้น 400 นี้แก้เพิ่มไปใช่ไหม
ใช่ครับผมลองทำดูก่อน เเต่ติด 400
เราเพื่ออะไรเข้าไป
จริงๆมันเป็นโค้ดคล้ายๆกันครับ ผมเพิ่มไปบางส่วน เอามาจากอีก example นึง
หรือว่ามี example ตัวอื่นเพิ่มเติมนอกเหนือจากนี้อีกไหมครับ
อู้วว ทำได้เเล้วครับ เช็คใน postman เเล้ว status 200 เเล้วครับ
แก้ไขอะไรเพิ่มเติมไปหรอครับถึงได้อธิบายหน่อย
ตรงที่ใส่ host จริงๆไม่ต้องใส่ https ใส่เป็นแค่ http ครับ เเล้วก็ไปผิดที่ error 401 อีก ก็ใส่ key ที่ fig ไว้ที่ url
เยี่ยมมากครับ ขอบคุณที่มาอัพเดท
