โค้ดแบบนี้ต้องต่อยังไงบ้างครับ
#define BLYNK_TEMPLATE_ID "TMPLxkfmRohc"
#define BLYNK_DEVICE_NAME "SmartFarm 2"
#define BLYNK_FIRMWARE_VERSION "0.1.0"
#define DHTPIN 15
#define DHTTYPE DHT11
//#define APP_DEBUG
#define USE_NODE_MCU_BOARD
#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
int SensorPin = A0;
int SensorValue = 0;
const int moisture1 = 32;
const int moisture2 = 33;
const int moisture3 = 34;
const int moisture4 = 35;
int moisture_value1 = 0;
int moisture_value2 = 0;
int moisture_value3 = 0;
int moisture_value4 = 0;
bool switchStatus = 0; // 0 = manual,1=auto
int soilMoistureLimit = 0;
bool manualSwitch = 0;
bool solenoid1 = 0;
bool solenoid2 = 0;
BLYNK_WRITE(V0)
switchStatus = param.asInt(); // Get value as integer
// update soilMosture setting
soilMoistureLimit = param.asInt(); // Get value as integer
// update manualSwitch
BLYNK_WRITE(V5)
manualSwitch = param.asInt();
BLYNK_WRITE(V6)
solenoid1 = param.asInt();
BLYNK_WRITE(V7)
solenoid2 = param.asInt();
#define PUMP D0
#define relayone D2
#define relaytwo D3
void manualAutoAction()
moisture_value1 = analogRead(moisture1);
moisture_value2 = analogRead(moisture2);
moisture_value3 = analogRead(moisture3);
moisture_value4 = analogRead(moisture4);
Serial.print("Moisture1 = ");
Serial.println(moisture_value1);
Serial.print("Moisture2 = ");
Serial.println(moisture_value2);
Serial.print("Moisture3 = ");
Serial.println(moisture_value3);
Serial.print("Moisture4 = ");
Serial.println(moisture_value4);
if(switchStatus)
// auto
if(moisture_value1 < soilMoistureLimit||(moisture_value2 < soilMoistureLimit))
digitalWrite(PUMP,HIGH);
digitalWrite(relayone,HIGH);
digitalWrite(PUMP,LOW);
digitalWrite(relayone,LOW);
if(moisture_value3 < soilMoistureLimit||(moisture_value4 < soilMoistureLimit))
digitalWrite(relaytwo,HIGH);
digitalWrite(relaytwo,LOW);
//manual
if(manualSwitch)
if(solenoid1)
if(solenoid2)
// manaul
void checkTemp()
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
Serial.begin(9400);
pinMode(PUMP,OUTPUT);
pinMode(relayone,OUTPUT);
pinMode(relaytwo,OUTPUT);
BlynkEdgent.begin();
timer.setInterval(1000L, manualAutoAction);
timer.setInterval(10000L, checkTemp);
BlynkEdgent.run();
SensorValue = analogRead(SensorPin);
SensorValue = map(SensorValue, 0, 1023, 0, 100);
