/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <DHT.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "01ac25b2ad62496f8a6848133ef0";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "maintenance";
char pass[] = "[quote="yothin, post:1, topic:2592, full:true"]
![Screenshot_2019-12-20-15-42-08-25_980d3cd05c70b8deb691e1a04aeb6aca|236x500](upload://rDqLegOOREVIbjqbnWrQnebQfso.png)
[/quote]
`Preformatted text`744130";
#define DHTPIN 14 // What digital pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
#define DHTTYPE DHT21 // DHT 21, AM2301
WidgetLED led_1(V1); //แสดงสถานะ Zone1 on/off
WidgetLED led_2(V2); //แสดงสถานะ Zone2 on/off
WidgetLED led_3(V3); //แสดงสถานะ Zone3 on/off
WidgetLED led_4(V4);//แสดงสถานะ Zone4 on/off
WidgetLED led_5(V10);//แสดงสถานะ main pump on/off
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
BLYNK_WRITE(V0)
// You'll get HIGH/1 at startTime and LOW/0 at stopTime.
// this method will be triggered every day
// until you remove widget or stop project or
// clean stop/start fields of widget
Serial.print("Got a value: ");
Serial.println(param.asInt());
if(param.asInt() == 0)
digitalWrite(D4, HIGH);
led_1.off();
led_2.off();
led_3.off();
led_4.off();
led_5.off();
if(param.asInt() == 1)
digitalWrite(D4, LOW);
led_1.on();
led_5.on();
delay(60000);
led_1.off();
led_2.on();
led_5.on();
delay(60000);
led_2.off();
led_3.on();
led_5.on();
delay(60000);
led_3.off();
led_4.on();
led_5.on();
delay(6000);
led_4.off();
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void sendSensor()
int val = analogRead(A0);
int s = map(val,0,1023,0,100);
float h = dht.readHumidity();
float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V7, s);
void setup()
// Debug console
Serial.begin(9600);
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
dht.begin();
// Setup a function to be called every second
timer.setInterval(1000L, sendSensor);
Blynk.run();
timer.run();
ต้องแบบไหนครับรบกวนด้วยครับ
ครับว่าจะเอาไว้ปรับ ค่า delay ทุกโซนครับ
ตอนนี้ slider ยังไม่ได้ผูกโค้ตใช่ไหมครับ
ใช่ครับว่าจะเอามาปรับค่าดีเลย์ของทุกโซนครับ
รอตัวอย่างการใช้งาน timer นะครับ
ลองดู ตัวอย่างนี้เพิ่มเติมครับ
ขอบคุณ คุณ Permpol มากครับ คำตอบของคุณ อาจเป็นประโยชน์ กับงานของผม
