char auth[] = "2ede26e45d1a416c9e0ee98aa7838fa3";
char ssid[] = "CIS-maintenance";
char pass[] = "62668163";
int vt1 = V1;
int pinValuevt1 = param.asInt(); // assigning incoming value from pin V1 to a variable
// You can also use:
//String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValuevt1);
pinMode(D0, OUTPUT);
digitalWrite(D0, HIGH); // turn the LED on (HIGH is the voltage level)
delay(vt1); // wait for a second
digitalWrite(D0, LOW); // turn the LED off by making the voltage LOW
delay(vt1);
char auth[] = "2ede26e45d1a";
char ssid[] = "ปปป-maintenance";
int vt1 = V1;
delay(vt1);
