#define LINE_TOKEN "FJVjCe9l03t9KNZQVyiCmeQh1LbFggi4lbYJkcILP2D"// line TOKEN
char auth[] = "-bmPvv6SZ8iN9uBkljI6Ubkv3V5df1ao"; // Blynk TOKEN
char ssid[] = "chayaphat";
char pass[] = "045425088";
int PIR = D1;
int Buzzer = D2;
int PIRStatus = 0;
int Status = 0;
WidgetLCD LCD(V0);
WidgetLED LED(V1);
pinMode(PIR,INPUT);
pinMode(Buzzer,OUTPUT);
Blynk.begin(auth, ssid, pass, IPAddress(49,229,108,138));
Blynk.connect();
BLYNK_WRITE(V2){
Serial.println(Status);
if (param.asInt()){
Status = 1;
LCD.clear();
LCD.print(1,0,"On The System");
LCD.print(4,1,"<<Mode>>");
LED.off();
Status = 0;
LED.off();
LCD.clear();
LCD.print(1,0,"Off The System");
digitalWrite(Buzzer, LOW);
void loop(){
if (Status == 1){
if (digitalRead(PIR)){
LCD.clear();
LCD.print(2,0,"Some One Come");
LCD.print(4,1,"<<Danger>>");
if (!PIRStatus){
PIRStatus = 1;
digitalWrite(Buzzer, HIGH);
Blynk.notify("Some One Come");
Line_Notify("Some One Come");
LED.on();
LCD.clear();
LCD.print(1,0,"Everything is OK ");
LCD.print(4,1,"<< OK >>");
LED.off();
PIRStatus = 0;
LED.off();
LED.off();
Serial.println("off");
axTLS::WiFiClientSecure client; // กรณีขึ้น Error ให้ลบ axTLS:: ข้างหน้าทิ้ง
String req = "";
req += "\r\n";
req += "message=" + message;
// Serial.println(req);
while(client.connected()) {
if (line == "\r") {
โค้ดมีปัญหาอะไรมั้ยคะ ช่วยหน่อยค่ะ
