เชื่อมแล้วก็เลิกเชื่อมเลยแก้ยังไงหรอครับ
นี้คือโค๊ดของผมครับช่วยดูหน่อยนะครับ
// define PIN Mapping
#define PIN_RELAY1 D5 // relay 1 HEATER
#define PIN_RELAY2 D6 // relay 2 PUMP
#define PIN_DHT D7 // dht temperture & humidity sensor
#define ON LOW
#define OFF HIGH
LiquidCrystal_I2C lcd(0x27,16,2);
#include <Adafruit_Sensor.h>
#include <DHT_U.h>
#define DHTPIN PIN_DHT
#define DHTTYPE DHT22 // DHT 22 (AM2302)
sensors_event_t event;
char auth[] = "-xECTkYDQRDrIhWLmMphguLGdkFAMZJb";
char ssid[] = "bigbossbest";
char pass[] = "0840749507";
float tempSensorData = 0;
float humiSensorData = 0;
bool autoCondition;
int limitHigh = 35;
int limitLow = 33;
void programProcess()
if(autoCondition)
Serial.println(limitHigh);
Serial.println(limitLow);
Serial.println(tempSensorData);
if(tempSensorData < limitLow)
//เปิด Heater
Serial.println("Condition 1");
digitalWrite(PIN_RELAY1,ON);
Blynk.virtualWrite(V11,HIGH);
if((tempSensorData >= limitLow) && (tempSensorData <= limitHigh))
//เปิด Heater
if(tempSensorData > limitHigh)
// ปืก Heater
Serial.println("Condition 2");
digitalWrite(PIN_RELAY1,OFF);
Blynk.virtualWrite(V11,LOW);
void updateSensor()
// check temperature
if (isnan(event.temperature)) {
Serial.println(F("Error reading temperature!"));
tempSensorData = event.temperature;
Serial.print(F("Temperature: "));
Serial.print(tempSensorData);
Serial.println(F("°C"));
Blynk.virtualWrite(V0,tempSensorData);
// check humidity
if (isnan(event.relative_humidity)) {
Serial.println(F("Error reading humidity!"));
humiSensorData = event.relative_humidity;
Serial.print(humiSensorData);
Serial.println(F("%"));
Blynk.virtualWrite(V1,humiSensorData);
void updateLCD()
if(autoCondition)
lcd.setCursor(13,0);
lcd.print("[A]");
lcd.print("[M]");
lcd.setCursor(2,1);
lcd.print(tempSensorData);
lcd.setCursor(10,1);
lcd.print(humiSensorData);
limitHigh = param.asInt();
BLYNK_WRITE(V3)
limitLow = param.asInt();
BLYNK_WRITE(V10)
autoCondition = param.asInt();
BLYNK_WRITE(V11)
if(!autoCondition)
if(param.asInt())
BLYNK_WRITE(V12)
if(param.asInt())
digitalWrite(PIN_RELAY2,LOW);
Blynk.setProperty(V11, "offLabel", "disable");
digitalWrite(PIN_RELAY2,HIGH);
Blynk.begin(auth, ssid, pass, "elec.cmtc.ac.th", 8080);
// Set Pin Mode Output
pinMode(PIN_RELAY1, OUTPUT);
pinMode(PIN_RELAY2 , OUTPUT);
// Set default PIN Value HIG=0,LOW=1
digitalWrite(PIN_RELAY1 , OFF);
digitalWrite(PIN_RELAY2 , OFF);
lcd.begin();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Smart Temp");
lcd.print("[M]");
lcd.setCursor(0,1);
lcd.print("T: H: ");
updateSensor();
timer.setInterval(2500L,updateSensor);
timer.setInterval(5000L,programProcess);
timer.setInterval(1000L,updateLCD);
ใช้ server ของใครครับ อันนี้คือ ส่งไป 2 ที่เลยเลือกเอาสักที่ครับ
ขอบคุณครับผม ผมไม่เห็นจริงๆครับ ใช้ server ของ วท.ชม. ครับ
