ช่วยด้วยครับแก้จนท้อแล้ว. แจ้งเตือนไลน์ได้พอเพิ่มcode google sheet ไลน์ไม่แจ้งเตือน
//----------------------------------------Include the NodeMCU ESP8266 Library
#include <HCSR04.h>
#include <WiFiClientSecure.h>
UltraSonicDistanceSensor distanceSensor(D7, D8);
#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
//#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
#define DHTPin D2
  String t;
#define ON_Board_LED 2  //--> Defining an On Board LED, used for indicators when the process of connecting to a wifi router
const char* auth = "FLtkZubxWNY86eDRG7-Xke7o8SSVMINM";
//----------------------------------------SSID dan Password wifi mu gan.
const char* ssid = "Pu_Ley 1_2.4GHz"; //--> Nama Wifi / SSID.
const char* password = "0635499306"; //-->  Password wifi .
//----------------------------------------Host & httpsPort
const char* host = "script.google.com";
const int httpsPort = 443;
#define LINE_TOKEN  "tS53ncQXmybWsthYxiz4J6Ojm8lWAxarUanRYQ5YdgE"
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
WiFiClientSecure client; //--> Create a WiFiClientSecure object.
// Timers auxiliar variables
String GAS_ID = "AKfycbwu1avyG5CGdDkB7-rJhMQJ14d0nJA0D1gmR-xFY2oETtB29k6DZ9PM1VkfX1rVktNlhg"; //--> spreadsheet script ID
bool a=0;
bool b=0;
bool c=0;
bool d=0;
bool e=0;
bool f=0;
//============================================ void setup
  Blynk.begin(auth, ssid, password,"blynk.cloud",80);
LINE.notify("Reset");
  WiFi.begin(ssid, password); //--> Connect to your WiFi router
  pinMode(ON_Board_LED,OUTPUT); //--> On Board LED port Direction output
  digitalWrite(ON_Board_LED, HIGH); //-->
  //----------------------------------------Wait for connection
  Serial.print("Connecting");
    //----------------------------------------Make the On Board Flashing LED on the process of connecting to the wifi router.
    digitalWrite(ON_Board_LED, LOW);
    delay(250);
    delay(250);
  digitalWrite(ON_Board_LED, HIGH); //--> Turn off the On Board LED when it is connected to the wifi router.
  //----------------------------------------If successfully connected to the wifi router, the IP Address that will be visited is displayed in the serial monitor
  Serial.print("Successfully connected to : ");
  Serial.println(ssid);
  Serial.print("IP address: ");
timer.setInterval(1000L,temp_humi);
timer.setInterval(1000L,cm);
timer.setInterval(1000L,blynk_);
  client.setInsecure();
  Blynk.virtualWrite(V5,255);
 void temp_humi()
    // Read temperature as Celsius (the default)
    // Read temperature as Fahrenheit (isFahrenheit = true)
    // Check if any reads failed and exit early (to try again).
    // Computes temperature values in Celsius
    static char temperatureTemp[7];
    dtostrf(hic, 6, 2, temperatureTemp);
    // Uncomment to compute temperature values in Fahrenheit
    // float hif = dht.computeHeatIndex(f, h);
    // static char temperatureTemp[7];
    // dtostrf(hif, 6, 2, temperatureTemp);
    static char humidityTemp[7];
    dtostrf(h, 6, 2, humidityTemp);
    Serial.print("Humidity: ");
    Serial.println(h);
    Serial.print(" %\t Temperature: ");
    Serial.println(t);
    Serial.print(" *C ");
    Serial.print(f);
    Serial.print(" *F\t Heat index: ");
    Serial.print(hic);
    Serial.println(" *C ");
    // Serial.print(hif);
    // Serial.println(" *F");
   Blynk.virtualWrite(V0,t);
    Blynk.virtualWrite(V1,h);
if(t>35&&c==0)
    Serial.println("temp_สูง");
    LINE.notify("ค่าอุณหภูมิสูง");
LINE.notify(t);
    c=1;
    d=0;
 if(t>25&&t<=35&&d==0)
   Serial.println("tempปกติ");
    LINE.notify("ค่าอุณหภูมิปกติ");
LINE.notify(t);
d=1;
  c=0;
  f=0;
    if(t<=25&&f==0)
    Serial.println("tempต่ำ");
    LINE.notify("ค่าอุณหภูมิต่ำ");
LINE.notify(t);
    f=1;
   if(h>60&&a==0)
  Serial.println("OK_a==1");
  a=1;
  b=0;
  LINE.notify("ค่าความชื้นสูง");
LINE.notify(h);
if(h>55&&h<=60&&b==0)
  Serial.println("OK_a==0");
  LINE.notify("ค่าความชื้นปกติ");
LINE.notify(h);
  a=0;
  b=1;
  e=0;
if(h<=55&&e==0)
Serial.println("Hiymidityต่ำ");
  LINE.notify("ค่าความชื้นต่ำ");
LINE.notify(h);
e=1;
 float value =t;
    float value2=h;
  Serial.println("==========");
  Serial.print("connecting to ");
  Serial.println(host);
  //----------------------------------------Connect to Google host
  if (!client.connect(host, httpsPort)) {
  //----------------------------------------Proses dan kirim data
  float string_temp = value;
  float string_humi = value2;
  String url = "/macros/s/" + GAS_ID + "/exec?temp=" + string_temp + "&humi="+string_humi; //  2 variables
  Serial.print("requesting URL: ");
  Serial.println(url);
         "Host: " + host + "\r\n" +
         "User-Agent: BuildFailureDetectorESP8266\r\n" +
         "Connection: close\r\n\r\n");
void blynk_()
  if(Blynk.connected())
    Serial.println("Connectted_to_blynk");
if(!Blynk.connected())
  LINE.notify("Connect_Blynk_fail");
  ESP.reset();
void cm()
  float i= distanceSensor.measureDistanceCm();
       Serial.print(i);
    Serial.println("CM");
    Serial.println("Level");
       Blynk.virtualWrite(V3,i);
ลองเอา
#define LINE_TOKEN “tS53ncQXmybWsthYxiz4J6Ojm8lWAxarUanRYQ5YdgE”
ไว้ด้านบนยังครับ
ย้ายแล้วครับยังไม่ได้
มันแจ้งเตือนแค่ตอนที่มันยังไม่ทำcode google sheets
แต่ถ้าทำไปแล้วรอบ1จะส่งไลน์ไม่ได้เลย
น่าจะมีปัญหาตรง code google sheets โค้ดไม่ถูก ไม่มี token ในการเชื่อมต่อ google sheets ถ้าทำได้แล้วอาจจะต้อง loop ให้ส่งใน LINE
ถ้าcodeตัวนี้สามรถส่งค่าไปgoogle sheetได้
ผมลองให้Code google sheetทำงาน1รอบ แต่ยังไม่ส่งไลน์เหมือนกับว่าถ้าcode google sheetทำงานได้1รอบมันจะบล็อคการส่งไลน์ครับ:cold_sweat::cold_sweat:
แต่ถ้าบอร์ด​Reset จะแจ้งในไลน์เพียงแค่ครั้งเดียว
เคยลองใส่whileให้ส่งไลน์ตลอดแล้วยังไม่ได้เหมือนเดิม:joy::joy::joy:
ลองเอา
ไว้ล่าง
ผมว่าชื่อ class น่าจะตีกันในระดับ library ครับ ต้องเข้าไปดูในนั้น
