ตามนี้เลยค่ะ
Error
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 231740 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26857 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1496 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 876 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25608 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 260969 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27980 bytes (34%) of dynamic memory, leaving 53940 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM3
Connecting...
Traceback (most recent call last):
File "C:\Users\nitro\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 519, in connect
last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 499, in _connect_attempt
self.sync()
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 438, in sync
timeout=SYNC_TIMEOUT)
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 376, in command
self.write(pkt)
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 339, in write
self._port.write(buf)
File "C:/Users/nitro/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial\serial\serialwin32.py", line 325, in write
raise SerialTimeoutException('Write timeout')
serial.serialutil.SerialTimeoutException: Write timeout
the selected serial port serial.serialutil.SerialTimeoutException: Write timeout
does not exist or your board is not connected
