Souliya999 (Souliya) August 13, 2020, 8:48am #1
#include <FS.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ESP8266WebServer.h>
#include <ArduinoJson.h>
#define SET_PIN 0
char blynk_token[40] = "";
void saveConfigCallback () {
shouldSaveConfig = true;
pinMode(SET_PIN, INPUT_PULLUP);
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
if (configFile) {
DynamicJsonBuffer jsonBuffer;
json.printTo(Serial);
if (json.success()) {
Serial.println("failed to load json config");
configFile.close();
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
if (digitalRead(SET_PIN) == LOW) {
wifiManager.resetSettings();
if (!wifiManager.autoConnect("Kitchenroom")) {
ESP.reset();
Serial.println("wifi connected");
if (shouldSaveConfig) {
if (!configFile) {
Serial.println("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
Serial.print("local ip : ");
Serial.print("Blynk Token : ");
Serial.println(blynk_token);
Blynk.config(blynk_token);
