#include <SoftwareSerial.h>
#define RE 8
#define DE 7
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
const byte nitro[] = {0x01,0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phos[] = {0x01,0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte pota[] = {0x01,0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
SoftwareSerial espSerial(5, 6);
int nitrogen();
int phosphorous();
int potassium();
String str;
byte values[11];
SoftwareSerial mod(2,3);
const int PUMP1 = A0;
const int PUMP2 = A1;
const int SOLENOID1 = A2;
const int SOLENOID2 = A3;
byte val1,val2,val3;
void setup(){
espSerial.begin(115200);
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
pinMode(PUMP1, OUTPUT);
pinMode(PUMP2, OUTPUT);
pinMode(SOLENOID1, OUTPUT);
pinMode(SOLENOID2, OUTPUT);
str =String(values[11]);
espSerial.println(str);
val1 = nitrogen();
delay(250);
val2 = phosphorous();
delay(250);
val3 = potassium();
delay(250);
if(val1,val2,val3<=20)
digitalWrite(SOLENOID1, LOW); // turn on solenoid2 10 seconds
digitalWrite(PUMP2, LOW); // turn on pump2 7 seconds
if(val1,val2,val3>20)
digitalWrite(SOLENOID2, HIGH); // turn on solenoid2 10 seconds
digitalWrite(PUMP2, HIGH); // turn off pump2 7 seconds
byte nitrogen(){
digitalWrite(DE,HIGH);
digitalWrite(RE,HIGH);
if(mod.write(nitro,sizeof(nitro))==8){
digitalWrite(DE,LOW);
digitalWrite(RE,LOW);
for(byte i=0;i<7;i++){
//Serial.print(mod.read(),HEX);
values[i] = mod.read();
Serial.print(values[i],HEX);
return values[4];
byte phosphorous()
if(mod.write(phos,sizeof(phos))==8)
return values[4];
byte potassium(){
if(mod.write(pota,sizeof(pota))==8){
return values[4];
error
C:\Users\Admin\Documents\Arduino\ssr3\ssr3.ino: In function 'void loop()':
ssr3:71:16: error: a function-definition is not allowed here before '{' token
byte nitrogen(){
ssr3:89:1: error: a function-definition is not allowed here before '{' token
ssr3:109:17: error: a function-definition is not allowed here before '{' token
byte potassium(){
