แก้ไข Error compiling for board NodeMCU 1.0 (ESP-12E Module)
        #include <SoftwareSerial.h>
        SoftwareSerial PZEMSerial;
        char auth[] = "aWq6tXF4V8w4gCPk23dS8vzYsX46HjAs";
        char ssid[] = "Deaun2";
        char pass[] = "57238840";
        #include <ModbusMaster.h>
        #define MAX485_DE  16
        #define MAX485_RE  5
        #define DHTTYPE DHT11   // DHT 11
        #define ON_Board_LED 2
        static uint8_t pzemSlaveAddr = 0x01;
        static uint16_t NewshuntAddr = 0x0000;
        ModbusMaster node;
        float PZEMVoltage =0;
        float PZEMCurrent =0;
        float PZEMPower =0;
        float PZEMEnergy=0;
        unsigned long startMillisPZEM;
        unsigned long currentMillisPZEM;
        const unsigned long periodPZEM = 1000;
        unsigned long startMillisReadData;
        unsigned long currentMillisReadData;
        const unsigned long periodReadData = 295000;
        int ResetEnergy = 0;
        int a = 1;
        unsigned long startMillis1;
        WiFiClientSecure client;
        startMillis1 = millis();
        PZEMSerial.begin(9600,SWSERIAL_8N2,4,0);
        WiFi.begin(ssid, pass);
        pinMode(ON_Board_LED,OUTPUT);
        digitalWrite(ON_Board_LED, HIGH);
        Serial.print("Connecting");
          digitalWrite(ON_Board_LED, LOW);
          delay(250);
          delay(250);
        Serial.print("Successfully connected to : ");
        Serial.println(ssid);
        Serial.print("IP address: ");
        client.setInsecure();
        startMillisPZEM = millis();
        pinMode(MAX485_RE, OUTPUT);
        pinMode(MAX485_DE, OUTPUT);
        digitalWrite(MAX485_RE, 0);
        digitalWrite(MAX485_DE, 0);
        node.preTransmission(preTransmission);
        node.begin(pzemSlaveAddr,PZEMSerial);
        startMillisReadData = millis();
        Serial.print("*");
        if ((millis()- startMillis1 >= 10000) && (a ==1))
          setShunt(pzemSlaveAddr);
          changeAddress(0XF8, pzemSlaveAddr);
          a = 0;
        currentMillisPZEM = millis();
        if (currentMillisPZEM - startMillisPZEM >= periodPZEM)
          uint8_t result;
          result = node.readInputRegisters(0x0000, 6);
          if (result == node.ku8MBSuccess)
              uint32_t tempdouble = 0x00000000;
              PZEMVoltage = node.getResponseBuffer(0x0000) / 100.0;
              PZEMCurrent = node.getResponseBuffer(0x0001) / 100.0;
              tempdouble =  (node.getResponseBuffer(0x0003) << 16) + node.getResponseBuffer(0x0002);
              PZEMPower = tempdouble / 10.0;
              tempdouble =  (node.getResponseBuffer(0x0005) << 16) + node.getResponseBuffer(0x0004);
              PZEMEnergy = tempdouble;
              if (pzemSlaveAddr==2)
              startMillisPZEM = currentMillisPZEM ;
        currentMillisReadData = millis();
        if (currentMillisReadData - startMillisReadData >= periodReadData)
            Serial.print("Vdc : "); Serial.print(PZEMVoltage); Serial.println(" V ");
            Serial.print("Idc : "); Serial.print(PZEMCurrent); Serial.println(" A ");
            Serial.print("Power : "); Serial.print(PZEMPower); Serial.println(" W ");
            Serial.print("Energy : "); Serial.print(PZEMEnergy); Serial.println(" Wh ");
            Blynk.virtualWrite(V0, PZEMVoltage);
            Blynk.virtualWrite(V1, PZEMCurrent);
            Blynk.virtualWrite(V2, PZEMPower);
            Blynk.virtualWrite(V3, PZEMEnergy);
            GG_ScriptSheet();
void CheckWiFi(){
        Serial.print("*");
void GG_ScriptSheet(){
  axTLS::WiFiClientSecure client;
  const char* HOST = "script.google.com";
  const char* GScriptId = "AKfycbyPl4hu242GL-idMzgAD4X8xDYMOYEWKEfT3n5DcYnKRcLXN7c";
  String url32 = String("/macros/s/") + GScriptId + "/exec?&FIELD1="+(String)PZEMVoltage +
      "&FIELD2="+(String)PZEMCurrent+
      "&FIELD3="+(String)PZEMPower+
      "&FIELD4="+(String)PZEMEnergy;
  Serial.print("Client.Connecting...");
  if (client.connect(HOST, 443)) {
    client.println("GET " + String(url32) + " HTTP/1.0"); //HTTP/1.0 OK sent LINEnotify and GoogleSheet
    client.println("Host: " + String(HOST));
    client.println("User-Agent: ESP8266\r\n");
    client.println("Connection: close\r\n\r\n");
    //client.println(true ? "" : "Connection: close\r\n");
    //client.println("Content-Type: application/x-www-form-urlencoded");
    client.println("Content-Type: application/json");
    //2client.println("Connection: close");
    client.println("Content-Length: " + String(url32.length()));
    client.println();
    //client.println(postData);
    client.print("\r\n\r\n");
    Serial.print("Response...");
  Serial.println("OK !!!");
void preTransmission()
        /* 1- PZEM-017 DC Energy Meter */
        if(millis() - startMillis1 > 5000)
          digitalWrite(MAX485_RE, 1);
          digitalWrite(MAX485_DE, 1);
          delay(1);
void postTransmission()
          delay(3);
void setShunt(uint8_t slaveAddr)
        static uint8_t SlaveParameter = 0x06;
        static uint16_t registerAddress = 0x0003;
        uint16_t u16CRC = 0xFFFF;        /* declare CRC check 16 bits*/
        u16CRC = crc16_update(u16CRC, slaveAddr);                                                         // Calculate the crc16 over the 6bytes to be send
        u16CRC = crc16_update(u16CRC, SlaveParameter);
        u16CRC = crc16_update(u16CRC, highByte(registerAddress));
        u16CRC = crc16_update(u16CRC, lowByte(registerAddress));
        u16CRC = crc16_update(u16CRC, highByte(NewshuntAddr));
        u16CRC = crc16_update(u16CRC, lowByte(NewshuntAddr));
        preTransmission();        /* trigger transmission mode*/
        PZEMSerial.write(slaveAddr);        /* these whole process code sequence refer to manual*/
        PZEMSerial.write(SlaveParameter);
        PZEMSerial.write(highByte(registerAddress));
        PZEMSerial.write(lowByte(registerAddress));
        PZEMSerial.write(highByte(NewshuntAddr));
        PZEMSerial.write(lowByte(NewshuntAddr));
        PZEMSerial.write(lowByte(u16CRC));
        PZEMSerial.write(highByte(u16CRC));
        postTransmission();        /* trigger reception mode*/
BLYNK_WRITE(V4)                                               // Virtual push button to reset energy for Meter 1
        if(param.asInt()==1)
            static uint8_t resetCommand = 0x42;               /* reset command code*/
            uint8_t slaveAddr = pzemSlaveAddr;                 // if you set different address, make sure this slaveAddr must change also
            u16CRC = crc16_update(u16CRC, resetCommand);
            PZEMSerial.write(slaveAddr);                      /* send device address in 8 bit*/
            PZEMSerial.write(resetCommand);                   /* send reset command */
            PZEMSerial.write(lowByte(u16CRC));                /* send CRC check code low byte  (1st part) */
            PZEMSerial.write(highByte(u16CRC));               /* send CRC check code high byte (2nd part) */
void changeAddress(uint8_t OldslaveAddr, uint8_t NewslaveAddr)                                            //Change the slave address of a node
        static uint8_t SlaveParameter = 0x06;                                                             /* Write command code to PZEM */
        static uint16_t registerAddress = 0x0002;                                                         /* Modbus RTU device address command code */
        u16CRC = crc16_update(u16CRC, OldslaveAddr);                                                      // Calculate the crc16 over the 6bytes to be send
        u16CRC = crc16_update(u16CRC, highByte(NewslaveAddr));
        u16CRC = crc16_update(u16CRC, lowByte(NewslaveAddr));
        PZEMSerial.write(OldslaveAddr);        /* these whole process code sequence refer to manual*/
        PZEMSerial.write(highByte(NewslaveAddr));
        PZEMSerial.write(lowByte(NewslaveAddr));
In file included from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:31:0,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/glue.h:53,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/arch/cc.h:61,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/lwip/arch.h:48,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/lwip/debug.h:40,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/lwipopts.h:3608,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/lwip/opt.h:51,
                 from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/lwip/ip_addr.h:40,
                 from C:\Users\Admin\AppData\Local\Arduino15\libraries\blynk-library-master\src/Blynk/BlynkProtocolDefs.h:81,
                 from C:\Users\Admin\AppData\Local\Arduino15\libraries\blynk-library-master\src/Blynk/BlynkApi.h:39,
                 from C:\Users\Admin\AppData\Local\Arduino15\libraries\blynk-library-master\src/BlynkApiArduino.h:14,
                 from C:\Users\Admin\AppData\Local\Arduino15\libraries\blynk-library-master\src/BlynkSimpleEsp8266.h:24,
                 from E:\psb_v1\psb_v1.ino:3:
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/ipv4_addr.h:53:22: error: field 'ip' has incomplete type
     struct ipv4_addr ip;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/ipv4_addr.h:54:22: error: field 'netmask' has incomplete type
     struct ipv4_addr netmask;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/ipv4_addr.h:55:22: error: field 'gw' has incomplete type
     struct ipv4_addr gw;
In file included from C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include/glue.h:53:0,
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:363:22: error: field 'ip' has incomplete type
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:368:22: error: field 'start_ip' has incomplete type
     struct ipv4_addr start_ip;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:369:22: error: field 'end_ip' has incomplete type
     struct ipv4_addr end_ip;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:532:22: error: field 'ip' has incomplete type
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:533:22: error: field 'mask' has incomplete type
     struct ipv4_addr mask;
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:534:22: error: field 'gw' has incomplete type
C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include/user_interface.h:544:22: error: field 'ip' has incomplete type
ขอคำอธิบายหน่อยครับ จำทำอะไร ทำอะไรไป แล้วเกิดอะไรขึ้น
