ขึ้น Error esptool.fatalerror failed to connect to esp8266 timed out waiting for packet header
ที่ผ่านมาก็ใช้ได้อยู่นะครับ วันนี้ลอง แก้โค้ดแล้ว upload บ่อยเกิน สักพักก็ขึ้นแบบนี้เลยครับ รบก่อนด้วยครับ
copy error มาวางหน่อยครับ
Arduino: 1.8.10 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM   : 234320          - code in flash         (default or ICACHE_FLASH_ATTR)
IRAM   : 27456   / 32768 - code in IRAM          (ICACHE_RAM_ATTR, ISRs...)
DATA   : 1240  )         - initialized variables (global, static) in RAM/HEAP
RODATA : 1652  ) / 81920 - constants             (global, static) in RAM/HEAP
BSS    : 24960 )         - zeroed variables      (global, static) in RAM/HEAP
Sketch uses 264668 bytes (25%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27852 bytes (33%) of dynamic memory, leaving 54068 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.7
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: dc:4f:22:5f:53:14
Uploading stub...
Running stub...
Stub running...
Traceback (most recent call last):
  File "C:\Users\AsiaManakkhong\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0/tools/upload.py", line 25, in <module>
    esptool.main(fakeargs)
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 2889, in main
    operation_func(esp, args)
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 2484, in flash_id
    flash_id = esp.flash_id()
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 607, in flash_id
    return self.run_spiflash_command(SPIFLASH_RDID, b"", 24)
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 853, in run_spiflash_command
    old_spi_usr = self.read_reg(SPI_USR_REG)
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 490, in read_reg
    val, data = self.command(self.ESP_READ_REG, struct.pack('<I', addr))
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 347, in command
    p = self.read()
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 292, in read
    return next(self._slip_reader)
  File "C:/Users/AsiaManakkhong/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 1999, in slip_reader
    raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
ภาพที่ต่อใช้งานด้วย
ตามนี้เลยครับ
ได้ผลไงแจ้งด้วยครับ
ยังไม่หายอะครับ
Arduino: 1.8.8 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
esptool.py v2.7
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
    p = self.read()
ดูหน้า comport มีกี่คอมครับ เลือกคอมถูกไหม
ตอนติดตั้ง บอร์ด ESP8266 ลองเลือกเป็น V.2.5.2 ดู ว่าคอมไพล์ได้ไหม
1.ถ้ายังไม่ได้ลองเปลี่ยนสาย USB ที่ใช้ หรือ
2.กดปุ่ม Reset ค้างไว้ หนึ่งครั้งแล้ว up ใหม่
กด RST ยังไม่ได้ เดี๋ยวลองเปลี่ยนสายดูครับ
ได้ไม่ได้แจ้งด้วยนะครับ จะได้สรุปประเด็นและปิดเคสนี้
@Asia_Manakkhong
เคสนี้สรุปผลหน่อยครับ
ของผมก็เป็นอะคับ ทำตามหมดเเล้วไม่ได้อะคับ
@Remy_Martin
มีบอร์ดสำรองไหมเอามาลองเปลี่ยนดูหน่อย
พีคับทำวิธีนี้ให้ดุให้หน่อยได้มัยคับ
เข้า flash mode โดย กดปุ่ม flash ค้างไว้ กดและปล่อยปุ่ม reset ปล่อยปุ่ม flash แล้วอัพโหลดใหม่
