สวัสดีค่ะ (มือใหม่มากๆไม่เข้าใจโค้ด) ขอความช่วยเหลือ วิธีการตรวจสอบ และแก้ไข Error ค่ะ
จะทำเซ็นเซอร์แจ้งเตือนขโมยค่ะ โค้ดที่เราใช้
//NaNa Projact By.Napaphat
#define USING_AXTLS
using namespace axTLS;
// Config connect WiFi
char auth[] = " ใส่Blynk_id";
#define WIFI_SSID "ใส่ชื่อ_Wifi"
#define WIFI_PASSWORD "ใส่รหัสผ่าน_Wifi"
// Line config
#define LINE_TOKEN "ใส่LineToKen_id"
#define SW D2
#define PiezoPin D7
String message = " -SOS- ! ! ! " ;
pinMode(SW, INPUT);
pinMode(PiezoPin, OUTPUT);
WiFi.mode(WIFI_STA);
// connect to wifi.
Blynk.begin(auth,WIFI_SSID,WIFI_PASSWORD);
Serial.print("connecting");
Serial.print("connected: ");
if (digitalRead(SW) == LOW) {
while (digitalRead(SW) == LOW)
Serial.println("Enter !");
Line_Notify(message);
loop:
digitalWrite(PiezoPin, HIGH);
digitalWrite(PiezoPin, LOW);
goto loop;
// Serial.println();
WiFiClientSecure client;
String req = "";
req += "\r\n";
req += "message=" + message;
// Serial.println(req);
while (client.connected()) {
if (line == "\r") {
//Serial.println(line);
Arduino: 1.8.9 (Windows 10), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Napaphat\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39,
from C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino:4:
C:\Users\Napaphat\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClient.h:89:10: error: conflicting return type specified for 'virtual size_t WiFiClient::availableForWrite()'
89 | size_t availableForWrite();
In file included from C:\Users\Napaphat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Stream.h:27,
from C:\Users\Napaphat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/HardwareSerial.h:32,
from C:\Users\Napaphat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:288,
from sketch\sketch_nano_som.ino.cpp:1:
C:\Users\Napaphat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Print.h:80:21: note: overridden function is 'virtual int Print::availableForWrite()'
80 | virtual int availableForWrite() { return 0; }
C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino: In function 'void setup()':
sketch_nano_som:14:12: error: 'D2' was not declared in this scope; did you mean 'V2'?
14 | #define SW D2
C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino:19:9: note: in expansion of macro 'SW'
19 | pinMode(SW, INPUT);
sketch_nano_som:15:18: error: 'D7' was not declared in this scope; did you mean 'V7'?
15 | #define PiezoPin D7
C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino:20:9: note: in expansion of macro 'PiezoPin'
20 | pinMode(PiezoPin, OUTPUT);
C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino: In function 'void loop()':
14 | #define SW D2
C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino:37:17: note: in expansion of macro 'SW'
37 | if (digitalRead(SW) == LOW) {
C:\Users\Napaphat\Documents\Arduino\sketch_nano_som\sketch_nano_som.ino:43:14: note: in expansion of macro 'PiezoPin'
43 | digitalWrite(PiezoPin, HIGH);
