char auth[] = “Vo8rf3KChr0f3xX69oEtMyJlXY3asz5h”; //token blynk
char ssid[] = “siri”; //ชื่อwifi
char pass[] = “1212312121”; //รหัสผ่าน wifi
#define BLYNK_Green “#23C48E”
#define BLYNK_Blue “#04C0F8”
#define BLYNK_Red “#D3435C”
#define BLYNK_White “#ffffff”
unsigned long time_switch;
int alarm_switch = 0;
WidgetLED led(V10);
BLYNK_WRITE(V0)
alarm_switch = param.asInt();
void led_blink() {
digitalWrite(2, !digitalRead(2));
byte input_pin = D2;
pinMode(2,OUTPUT);
pinMode(input_pin, INPUT_PULLUP);
Serial.println(“”);
Serial.println(“Connected”);
timer.setInterval(1000L, led_blink);
led.on();
time_switch = millis();
if (millis() - time_switch > 1000) {
if (digitalRead(input_pin) == LOW) {
delay(50);
led.setColor(BLYNK_Green);
Serial.println(“closed”);
delay(50);
if (alarm_switch == 1) {
led.setColor(BLYNK_Red);
Blynk.notify(“แจ้งเตือน : ประตูเปิด”);
while (digitalRead(input_pin) == HIGH) {
led.setColor(BLYNK_Blue);
Serial.println(“open”);
