ESP32 เชื่อมต่อ BLYNK แล้วหลุดทำอย่างไรให้มีการ Reconnect เมื่อหลุด
code
#define BLYNK_TEMPLATE_ID "TMPLxzJ5naNs"
#define BLYNK_DEVICE_NAME "Pump"
#define BLYNK_AUTH_TOKEN "BtOEe50CeVdS90-OuWlT_-F_xywnK0jl"
// Comment this out to disable prints and save space
#define relay1 33
#define relay2 25
#define relay3 26
#define relay4 27
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "TMTFACGUEST";
char pass[] = "TMTst33l@tmtwifi";
BLYNK_WRITE(V0){
  if (param.asInt() == 0 ){
    digitalWrite(relay1 , HIGH);
  else if(param.asInt() == 1){
    digitalWrite(relay1, LOW);
BLYNK_WRITE(V1){
    digitalWrite(relay2 , HIGH);
    digitalWrite(relay2, LOW);
BLYNK_WRITE(V2){
    digitalWrite(relay3 , HIGH);
    digitalWrite(relay3, LOW);
BLYNK_WRITE(V3){
    digitalWrite(relay4 , HIGH);
    digitalWrite(relay4, LOW);
void myTimerEvent()
  Blynk.virtualWrite(V5, millis() / 1000);
/*void ConnectWiFi(){
  WiFi.begin(ssid,pass);
  if (WiFi.status () !=WL_CONNECTED){
    Serial.print("concnect");
    Serial.print("Failed");
  Serial.println("connected to wifi network");
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  digitalWrite(relay1, HIGH);
  digitalWrite(relay2, HIGH);
  digitalWrite(relay3, HIGH);
  digitalWrite(relay4, HIGH);
  //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
  timer.setInterval(1000L, myTimerEvent);
  //ConnectWiFi();
หลัง BlynkTimer timer;
ใส่ int blynkIsDownCount = 0;
หลัง timer.setInterval(1000L, myTimerEvent);
ใส่ timer.setInterval(30000L, reconnecting); //Function reconnect
จากจากนั้น วาง void reconnecting() หลัง Void loop
void reconnecting()
  if (!Blynk.connected())
    blynkIsDownCount++;
    Blynk.connect(5000);
อันนี้แค่ให้ลองนะครับ
