C:\Program Files (x86)\Arduino\libraries\TridentTD_LineNotify-master\src\TridentTD_LineNotify.cpp: In member function ‘bool TridentTD_LineNotify::_notify(String, int, int, String, fs::FS&, String, uint8_t*, size_t)’:
C:\Program Files (x86)\Arduino\libraries\TridentTD_LineNotify-master\src\TridentTD_LineNotify.cpp:122:17: error: ‘class WiFiClientSecure’ has no member named ‘setInsecure’
_clientSecure.setInsecure();
Error compiling for board ESP32 Wrover Module.
ขึ้นแบบนี้เป็นเพราะอะไรครับ
#include "esp_camera.h"
#include "esp_system.h"
hw_timer_t *timer = NULL;
void IRAM_ATTR resetModule(){
ets_printf("reboot\n");
esp_restart();
#define SSID "JOKESAHAGON" //WiFi name
#define PASSWORD "jokekpru" //PASSWORD
#define LINE_TOKEN "4UHqpwCOLMM4vstQlKm7XpwDw9eqCWl2uqr5yNqHuiP"
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
const int Led_Flash = 4;
const int Led_run = 13;
int PIR_Sensor = 12;
boolean startTimer = false;
unsigned long time_now=0;
int time_capture=0;
while (!Serial) { ; }
pinMode(Led_Flash, OUTPUT);
pinMode(Led_run, OUTPUT);
WiFi.begin(SSID, PASSWORD);
timer = timerBegin(0, 80, true); //timer 0, div 80Mhz
timerAttachInterrupt(timer, &resetModule, true);
timerAlarmWrite(timer, 20000000, false); //set time in us 15s
timerAlarmEnable(timer); //enable interrupt
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
if(psramFound()){
// FRAMESIZE_ +
//QQVGA/160x120//QQVGA2/128x160//QCIF/176x144//HQVGA/240x176
//QVGA/320x240//CIF/400x296//VGA/640x480//SVGA/800x600//XGA/1024x768
//SXGA/1280x1024//UXGA/1600x1200//QXGA/2048*1536
config.frame_size = FRAMESIZE_VGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_QQVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// Init Camera
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
timerWrite(timer, 0); //reset timer (feed watchdog)
long tme = millis();
if(digitalRead(PIR_Sensor) == 1 && startTimer != true){
Camera_capture();
Serial.println("OK");
startTimer = true;
}else if(digitalRead(PIR_Sensor) == 0){
startTimer = false;
time_capture=0;
if(millis() > time_now + 1000) {
time_now = millis();
digitalWrite(Led_run, HIGH);
digitalWrite(Led_run, LOW);
tme = millis() - tme;
if(digitalRead(PIR_Sensor) == 1){
if(++time_capture > 60){
time_capture=0;
Camera_capture();
Serial.println("Over Time");
Serial.println(digitalRead(PIR_Sensor));
delay(200);
void Camera_capture() {
digitalWrite(Led_Flash, HIGH);
digitalWrite(Led_Flash, LOW);
camera_fb_t * fb = NULL;
delay(200);
// Take Picture with Camera
fb = esp_camera_fb_get();
if(!fb) {
Serial.println("Camera capture failed");
Send_line(fb->buf,fb->len);
esp_camera_fb_return(fb);
// Serial.println("Going to sleep now");
// esp_deep_sleep_start();
// Serial.println("This will never be printed");
void Send_line(uint8_t *image_data,size_t image_size){
LINE.notifyPicture("ตรวจพบการเคลื่อนไหว",image_data, image_size);
แก้ได้เเล้วครับ ไปดูใน C:\Program Files (x86)\Arduino\libraries\TridentTD_LineNotify-master\src มา แล้วปรับ board esp32 ใน board manager เป็น 1.0.4 ตามคำแจ้งเตือนบรรทัดที่ 122 คือ ARDUINO_ESP32_RELEASE_1_0_4
แต่ปัญหาใหม่คือ ไม่ได้รับ ip จาก wifi ครับ 06fq ยาวเลย
ปัญหานี้เหมือนว่าจะใส่ ssid , password ผิดมากกว่าเพราะเหมือนมันกำลัง connect กับ internet เเล้วยัง connect ไม่ได้ ตามโค้ดบรรทัดนี้เลยครับ
ถ้ายังไม่ connect ก็จะ output . ออกมาเรื่อยๆ เดาได้ว่า ssid,password ผิด
Remy_Martin
(Permpol Thanapunnamas)
มิถุนายน 23, 2022, 12:01pm
7
ใช่ครับ ต้องดูตัวท้ายที่ลงด้วย _2.4G ดีๆ ต้องใส่ด้วย
