Esp32 ขึ้น Error esp_camera.h
#include "esp_camera.h"
#include "esp_system.h"
hw_timer_t *timer = NULL;
void IRAM_ATTR resetModule(){
    ets_printf("reboot\n");
    esp_restart();
#define SSID        "D"   //WiFi name
#define PASSWORD    "11111111"   //PASSWORD
#define LINE_TOKEN  "."
char auth[] = ".";//another board
#define CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
int PIR_Sensor = 12;
boolean startTimer = false;
unsigned long time_now=0;
int time_capture=0;
   while (!Serial) {  ;  }
  Blynk.begin(auth, SSID, PASSWORD);
  WiFi.begin(SSID, PASSWORD);
    timer = timerBegin(0, 80, true); //timer 0, div 80Mhz
    timerAttachInterrupt(timer, &resetModule, true);
    timerAlarmWrite(timer, 20000000, false); //set time in us 15s
    timerAlarmEnable(timer); //enable interrupt
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
// FRAMESIZE_ +
//QQVGA/160x120//QQVGA2/128x160//QCIF/176x144//HQVGA/240x176
//QVGA/320x240//CIF/400x296//VGA/640x480//SVGA/800x600//XGA/1024x768
//SXGA/1280x1024//UXGA/1600x1200//QXGA/2048*1536
    config.frame_size = FRAMESIZE_VGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_QQVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
void picture(){ timerWrite(timer, 0); //reset timer (feed watchdog)
int cat=analogRead(PIR_Sensor);
    cat/=10.2;
    long tme = millis();
    if(cat <= 210 && startTimer != true){
           Camera_capture();
           Serial.println("OK");
           startTimer = true;
      }else if(cat >210){
        startTimer = false;
        time_capture=0;
     if(millis() > time_now + 10000) {
           time_now = millis();
         tme = millis() - tme;
      if(cat<= 210){
         if(++time_capture > 60){
            time_capture=0;
            Camera_capture();
            Serial.println("Over Time");
      Serial.println(cat);
      delay(200);}
   picture();
void Camera_capture() {
  camera_fb_t * fb = NULL;
  delay(200);
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
   Send_line(fb->buf,fb->len);
   esp_camera_fb_return(fb);
  // Serial.println("Going to sleep now");
  // esp_deep_sleep_start();
  // Serial.println("This will never be printed");
void Send_line(uint8_t *image_data,size_t   image_size){
   LINE.notifyPicture("ตรวจพบการเคลื่อนไหว",image_data, image_size);
void Send_linephoto(uint8_t *image_data,size_t   image_size){
   LINE.notifyPicture(image_data, image_size);
void takephoto(){
  delay(200);
  if(!fb) {
   Send_linephoto(fb->buf,fb->len);
BLYNK_WRITE(V0){
  if(param.asInt()==1){
    takephoto()
testcammmm.ino (4.9 KB)
ติดตั้ง library esp_camera.h ด้วยครับ
ผมลองหาในเน็ตแล้วไม่เจอครับ
เลือกแบบนี้ถูกรึป่าวครับ
ไม่ Error แล้วครับ ลืมเลือกบอร์ด
nathan fillion hd GIF
