ช่วยหน่อยครับผมโช้โค๊ตอัพลงได้ปกติเเต่ESP8266มันไม่กระจายสัญญานWIFi
เเต่ลองรันโค๊ตตัวอย่างอีกตัวดูมันก็ขึ้นชื่อwifi ให้เชื่อมต่อครับ
อันนี้คือโค๊ตที่ต้องใช้เเล้วมันไม่ขึ้น
#define BT1 D1
#define BT2 D2
#define BT3 D3
char auth[] = "udyYsrZspqRGfIDf05maaINmA5SEGRuh";
char ssid[] = "oansm";
char pass[] = "0987654321";
WidgetLCD lcd1(V0);
WidgetLED BT1Blynk(V10);
WidgetLED BT2Blynk(V11);
WidgetLED BT3Blynk(V12);
digitalWrite(BT1, LOW);
digitalWrite(BT2, LOW);
digitalWrite(BT3, LOW);
lcd1.clear();
lcd1.print(3,0,"Smart Fan");
lcd1.print(5,1,"Controller");
pinMode(BT1,OUTPUT);
pinMode(BT2,OUTPUT);
pinMode(BT3,OUTPUT);
BLYNK_WRITE(V1){
if (param.asInt()){
digitalWrite(BT1, HIGH);
lcd1.clear();
lcd1.print(4,0,"On Number");
lcd1.print(8,1,"1");
BT1Blynk.on();
BT2Blynk.off();
BT3Blynk.off();
Blynk.virtualWrite(V2,0);
Blynk.virtualWrite(V3,0);
lcd1.clear();
lcd1.print(7,0,"Off");
BT1Blynk.off();
BLYNK_WRITE(V2){
if (param.asInt()){
digitalWrite(BT2, HIGH);
lcd1.clear();
lcd1.print(8,1,"2");
BT2Blynk.on();
BT1Blynk.on();
BT1Blynk.off();
BT3Blynk.off();
Blynk.virtualWrite(V1,0);
lcd1.clear();
BT2Blynk.off();
BLYNK_WRITE(V3){
if (param.asInt()){
digitalWrite(BT3, HIGH);
lcd1.clear();
lcd1.print(8,1,"3");
BT3Blynk.on();
BT1Blynk.off();
BT2Blynk.off();
lcd1.clear();
BT3Blynk.off();
BLYNK_WRITE(V4){
lcd1.clear();
lcd1.print(5,0,"Off All");
BT1Blynk.on();
BT1Blynk.off();
BT2Blynk.off();
BT3Blynk.off();
