ผมอยากให้Textfieldคำว่าTeam A กับTeam B มันอยู่ข้างกันอะครับ
ผมลองใช้Rowแล้วมันerror มันพอมีวิธีอื้นไหมครับที่จะให้อยู่ข้างกันแบบตามที่ผมออกแบบ
import 'package:flutter/material.dart';
void main() {
runApp(MyApp());
class MyApp extends StatelessWidget {
// This widget is the root of your application.
@override
Widget build(BuildContext context) {
return MaterialApp(
title: 'Flutter Demo',
theme: ThemeData(
// is not restarted.
primarySwatch: Colors.blue,
backgroundColor: Colors.black38
home: MainPage(),
class MainPage extends StatefulWidget {
@override
_MainPageState createState() => _MainPageState();
class _MainPageState extends State<MainPage> {
final Team_A_Name = "Team Name";
final Team_B_Name = "Team Name";
TextEditingController TeamA = TextEditingController(text: "");
TextEditingController TeamB = TextEditingController(text: "");
@override
return Scaffold(
backgroundColor: Colors.black38,
/*appBar: AppBar(
title: Text("TimeCountDown"),
backgroundColor: Colors.white54,
body: Center(
child: Column(children: <Widget>[
SizedBox(height: 20,),
Padding(
padding: const EdgeInsets.all(8.0),
child: TextField(
decoration: InputDecoration(
/*labelText: Team_A_Name,
labelStyle: TextStyle(fontSize: 24,
color: Colors.red,
fontStyle: FontStyle.normal
hintText: "$Team_A_Name",
hintStyle: TextStyle(fontSize: 24, color: Colors.red),
border: InputBorder.none,
obscureText: false,
maxLength: 20,
maxLines: 2,
textInputAction: TextInputAction.done,
controller: TeamA,style: TextStyle(fontSize: 24),
Padding(
child: TextField(
color: Colors.red,
hintText: "$Team_B_Name",
hintStyle: TextStyle(fontSize: 24, color: Colors.indigo),
obscureText: false,
maxLength: 20,
maxLines: 2,
controller: TeamB,
style: TextStyle(
fontSize: 24,
color: Colors.white
ลองดูว่าเป็นไง
void main() {
runApp(MyApp());
@override
return MaterialApp(
theme: ThemeData(
home: MainPage(),
@override
@override
return Scaffold(
/*appBar: AppBar(
body: Center(
Row(
Padding(
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
Padding(
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
controller: TeamB,
style: TextStyle(
fontSize: 24,
color: Colors.white
), //Row
errorตรง2บรรทัดนี้อะครับผมเอาออกถึงหายerror
void main() {
runApp(MyApp());
@override
return MaterialApp(
theme: ThemeData(
home: MainPage(),
@override
@override
return Scaffold(
/*appBar: AppBar(
body: Center(
child: Row
Column(
children: [
Padding(
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
Padding(
child: TextField(
obscureText: false,
maxLength: 20,
maxLines: 2,
controller: TeamB,
style: TextStyle(
fontSize: 24,
color: Colors.white
//Row
Errorที่ขึ้น
Performing hot reload...
Syncing files to device Android SDK built for x86...
======== Exception caught by rendering library =====================================================
The following assertion was thrown during performLayout():
An InputDecorator, which is typically created by a TextField, cannot have an unbounded width.
This happens when the parent widget does not provide a finite width constraint. For example, if the InputDecorator is contained by a Row, then its width must be constrained. An Expanded widget or a SizedBox can be used to constrain the width of the InputDecorator or the TextField that contains it.
'package:flutter/src/material/input_decorator.dart':
Failed assertion: line 948 pos 7: 'layoutConstraints.maxWidth < double.infinity'
Either the assertion indicates an error in the framework itself, or we should provide substantially more information in this error message to help you determine and fix the underlying cause.
In either case, please report this assertion by filing a bug on GitHub:
https://github.com/flutter/flutter/issues/new?template=2_bug.md
The relevant error-causing widget was:
TextField file:///C:/Users/Admin/background/lib/main.dart:50:26
When the exception was thrown, this was the stack:
#2 _RenderDecoration._layout (package:flutter/src/material/input_decorator.dart:948:7)
#3 _RenderDecoration.performLayout (package:flutter/src/material/input_decorator.dart:1294:44)
#4 RenderObject.layout (package:flutter/src/rendering/object.dart:1777:7)
#5 RenderProxyBoxMixin.performLayout (package:flutter/src/rendering/proxy_box.dart:120:14)
#6 RenderObject.layout (package:flutter/src/rendering/object.dart:1777:7)
The following RenderObject was being processed when the exception was fired: _RenderDecoration#bebd3 relayoutBoundary=up9 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... parentData: <none> (can use size)
... constraints: BoxConstraints(unconstrained)
... size: MISSING
RenderObject: _RenderDecoration#bebd3 relayoutBoundary=up9 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... input: RenderRepaintBoundary#237fc NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... needs compositing
... parentData: offset=Offset(0.0, 0.0)
... constraints: MISSING
... size: MISSING
... usefulness ratio: no metrics collected yet (never painted)
... child: RenderMouseRegion#3ac52 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... size: MISSING
... listeners: <none>
... child: RenderRepaintBoundary#d5961 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... size: MISSING
... child: RenderCustomPaint#a8ca0 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... size: MISSING
... hint: RenderAnimatedOpacity#60007 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... size: MISSING
... opacity: AnimationController#cb272(⏮ 0.000; paused; for AnimatedOpacity)➩Cubic(0.40, 0.00, 0.20, 1.00)➩Tween<double>(1.0 → null)➩1.0
... alwaysIncludeSemantics
... child: RenderParagraph#3dec8 NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
... textAlign: start
... textDirection: ltr
... softWrap: wrapping at box width
... overflow: ellipsis
... locale: en_US
... maxLines: 2
... text: TextSpan
... debugLabel: ((((englishLike subhead 2014).merge(blackMountainView subtitle1)).merge(unknown)).copyWith).merge(unknown)
... inherit: false
... color: MaterialColor(primary value: Color(0xfff44336))
... family: Roboto
... size: 24.0
... weight: 400
... baseline: alphabetic
... decoration: TextDecoration.none
... "Team Name"
... helperError: RenderConstrainedBox#56202 NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
... additionalConstraints: BoxConstraints(unconstrained)
... counter: RenderSemanticsAnnotations#40898 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... semantic boundary
... size: MISSING
... child: RenderSemanticsAnnotations#315dd NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... size: MISSING
... child: RenderExcludeSemantics#43364 NEEDS-LAYOUT NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
... size: MISSING
... excluding: true
... child: RenderParagraph#ac6de NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
... locale: en_US
... maxLines: unlimited
... container: RenderCustomPaint#1f744 NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
RenderBox was not laid out: _RenderDecoration#bebd3 relayoutBoundary=up9 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
'package:flutter/src/rendering/box.dart':
Failed assertion: line 1920 pos 12: 'hasSize'
RenderBox was not laid out: RenderPointerListener#76bb4 relayoutBoundary=up8 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
RenderBox was not laid out: RenderSemanticsAnnotations#76745 relayoutBoundary=up7 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
RenderBox was not laid out: RenderIgnorePointer#9dac5 relayoutBoundary=up6 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
RenderBox was not laid out: RenderMouseRegion#177e7 relayoutBoundary=up5 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
Padding file:///C:/Users/Admin/background/lib/main.dart:48:19
RenderBox was not laid out: RenderPadding#9c1f3 relayoutBoundary=up4 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
Column file:///C:/Users/Admin/background/lib/main.dart:46:15
RenderBox was not laid out: RenderFlex#9311e relayoutBoundary=up3 NEEDS-PAINT NEEDS-COMPOSITING-BITS-UPDATE
Row file:///C:/Users/Admin/background/lib/main.dart:43:16
'package:flutter/src/rendering/shifted_box.dart': Failed assertion: line 341 pos 12: 'child!.hasSize': is not true.
Center file:///C:/Users/Admin/background/lib/main.dart:42:13
Reloaded 1 of 536 libraries in 1,812ms.
The following _CastError was thrown during paint():
Null check operator used on a null value
#0 RenderFlex._hasOverflow (package:flutter/src/rendering/flex.dart:489:37)
#1 RenderFlex.paint (package:flutter/src/rendering/flex.dart:1078:10)
#2 RenderObject._paintWithContext (package:flutter/src/rendering/object.dart:2315:7)
#3 PaintingContext.paintChild (package:flutter/src/rendering/object.dart:189:13)
#4 RenderShiftedBox.paint (package:flutter/src/rendering/shifted_box.dart:72:15)
The following RenderObject was being processed when the exception was fired: RenderFlex#82887 relayoutBoundary=up2
... parentData: offset=Offset(0.0, 0.0) (can use size)
... constraints: BoxConstraints(0.0<=w<=411.4, 0.0<=h<=820.6)
... size: MISSING
... direction: horizontal
... mainAxisAlignment: start
... mainAxisSize: max
... crossAxisAlignment: center
... verticalDirection: down
RenderObject: RenderFlex#82887 relayoutBoundary=up2
needs compositing
mainAxisSize: max
textDirection: ltr
... child 1: RenderFlex#9311e relayoutBoundary=up3 NEEDS-PAINT
... parentData: offset=Offset(0.0, 0.0); flex=null; fit=null (can use size)
... constraints: BoxConstraints(0.0<=w<=Infinity, 0.0<=h<=820.6)
... size: MISSING
... direction: vertical
... child 1: RenderPadding#9c1f3 relayoutBoundary=up4 NEEDS-PAINT
... size: MISSING
... padding: EdgeInsets.all(8.0)
... child: RenderMouseRegion#177e7 relayoutBoundary=up5 NEEDS-PAINT
... parentData: offset=Offset(8.0, 8.0) (can use size)
... size: MISSING
... listeners: enter, exit
... cursor: SystemMouseCursor(text)
... child: RenderIgnorePointer#9dac5 relayoutBoundary=up6 NEEDS-PAINT
... size: MISSING
... ignoring: false
... ignoringSemantics: implicitly false
... child 2: RenderPadding#9aaf9 NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
... child: RenderMouseRegion#b7c55 NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
... child: RenderIgnorePointer#d409c NEEDS-LAYOUT NEEDS-PAINT
... size: MISSING
... ignoring: false
ลองดูอันนี้
void main() {
runApp(MyApp());
@override
return MaterialApp(
theme: ThemeData(
home: MainPage(),
@override
@override
return Scaffold(
/*appBar: AppBar(
body: Center(
Row(
Padding(
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
Padding(
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
controller: TeamB,
style: TextStyle(
fontSize: 24,
color: Colors.white
), //Row
ลบ Row() ออก ใส่ alignment ให้มัน
void main() {
runApp(MyApp());
@override
return MaterialApp(
theme: ThemeData(
home: MainPage(),
@override
@override
return Scaffold(
/*appBar: AppBar(
body: Center(
Padding(
alignment: Alignment.topLeft,
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
Padding(
alignment: Alignment.topRight,
child: TextField(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
controller: TeamB,
style: TextStyle(
fontSize: 24,
color: Colors.white
ย้าย Sizebox กลับมาไว้ที่เดิมด้วย
void main() {
runApp(MyApp());
@override
return MaterialApp(
theme: ThemeData(
home: MainPage(),
@override
@override
return Scaffold(
/*appBar: AppBar(
body: Center(
Padding(
child: TextField1(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
child: TextField2(
color: Colors.red,
obscureText: false,
maxLength: 20,
maxLines: 2,
อันนี้codeปัจจุบันที่ผมเขียนต่อจากอันบนแต่ก็ยังเอาTextfiledไปอยู่ข้างกันไม่ได้
import 'package:image_picker/image_picker.dart';
import 'package:path/path.dart';
void main() {
runApp(MyApp());
//runApp(imageTeam());
@override
return MaterialApp(
theme: ThemeData(
//home: MainPage(),
home: imageTeam(),
class imageTeam extends StatefulWidget {
@override
_imageTeamState createState() => _imageTeamState();
class _imageTeamState extends State<imageTeam> {
final title = "ScoreDy";
@override
return Scaffold(
appBar: AppBar(
backgroundColor: Colors.black12,
title:Text(title),
centerTitle: true,
titleTextStyle:
TextStyle(
fontSize: 50,
fontWeight: FontWeight.bold,
body: Builder(
builder: (context)=> Container(
child: Column(
mainAxisAlignment: MainAxisAlignment.start,
children: <Widget>[
Row(
children: [
Column(
children: [
Align(
child: Padding(
padding: const EdgeInsets.only(
left: 20.0,
top: 20.0),
child: CircleAvatar(
radius: 80,
Align(
child: Padding(
left: 50.0,
right: 20.0,
top: 20.0,
radius: 80,
SizedBox(height: 30,),
Column(
children: [
Align(
alignment: Alignment.center,
child: Padding(
left: 35.0,
right: 30,
child: TextField(
color: Colors.red,
fontSize: 24,
color: Colors.red
fontSize: 24,
color: Colors.red
Align(
alignment: Alignment.centerRight,
child: Padding(
right: 30.0,
left: 230.0
child: TextField(
/*labelText: Team_B_Name,
color: Colors.red,
fontSize: 24,
color: Colors.indigo,
maxLines: 2,
controller: TeamB,
style: TextStyle(
fontSize: 24,
