// ตัวอย่างตัวส่ง
//#include<heltec.h>
#include <U8x8lib.h>
#include <LoRa.h>
#include <SPI.h>
String receivedText;
String receivedRssi;
// WIFI_LoRa_32 ports
// GPIO5 -- SX1278's SCK
// GPIO19 -- SX1278's MISO
// GPIO27 -- SX1278's MOSI
// GPIO18 -- SX1278's CS
// GPIO14 -- SX1278's RESET
// GPIO26 -- SX1278's IRQ(Interrupt Request)
#define Phase_A 37
#define SS 18
#define RST 14
#define DI0 26
#define BAND 433E6
#define PABOOST true
// the OLED used
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(15,4,16);
//double BAND = 433E6;
int counter = 0;
int Value_A = 0;
pinMode(25,OUTPUT); //Send success, LED will bright 1 second
u8x8.begin();
u8x8.setFont(u8x8_font_chroma48medium8_r);
Serial.println("LoRa Sender");
u8x8.drawString(0, 1, "LoRa Sender");
SPI.begin(5,19,27,18);
LoRa.setPins(SS,RST,DI0);
LoRa.setTxPower(20);
LoRa.setSpreadingFactor(12);
LoRa.setCodingRate4(5);
LoRa.setSignalBandwidth(125E3); //
LoRa.setPreambleLength(8);
if (!LoRa.begin(BAND,PABOOST)) {
u8x8.drawString(0, 1, "Starting LoRa failed!");
while (1);
Serial.println("LoRa Initial OK!");
Value_A = analogRead(Phase_A);
//Serial.print(Value_A);
Serial.print("Sending packet: ");
u8x8.drawString(0, 4, "PacketID");
Serial.println(counter);
String txt = String(counter);
char currentid[5];
txt.toCharArray(currentid, 64);
u8x8.drawString(9, 4, currentid);
Serial.print("ADC: ");
u8x8.drawString(0, 6, "ADC");
Serial.println(Value_A);
String txt1 = String(Value_A);
char currentid1[5];
txt1.toCharArray(currentid1, 64);
u8x8.drawString(5, 6, currentid1);// 6 >> 3
//Serial.println(" ");
//u8x8.drawString(0, 5, "ADC");
//LoRa.print(Phase_A);
// send packet
LoRa.beginPacket();
//LoRa.print("hello ");
LoRa.print(counter);
LoRa.println(Value_A);
LoRa.endPacket();
//u8x8.drawString(0, 5, "Payload");
// u8x8.drawString(9, 5, "LORA");
counter++;
digitalWrite(25, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(25, LOW); // turn the LED off by making the voltage LOW
//delay(3000);
// ตัวอย่างตัวรับ
#include <LoRa.h>
String receivedText1;
// Pin definetion of WIFI LoRa 32
#define SCK 5 // GPIO5 -- SX127x's SCK
#define MISO 19 // GPIO19 -- SX127x's MISO
#define MOSI 27 // GPIO27 -- SX127x's MOSI
#define SS 18 // GPIO18 -- SX127x's CS
#define RST 14 // GPIO14 -- SX127x's RESET
#define DI0 26 // GPIO26 -- SX127x's IRQ(Interrupt Request)
#define BAND 433E6 //you can set band here directly,e.g. 868E6,915E6
// the OLED used
SPI.begin(5, 19, 27, 18);
LoRa.setPins(SS, RST, DI0);
u8x8.begin();
Serial.println("LoRa Receiver");
u8x8.drawString(0, 0, "LoRa Receiver"); // 0
//u8x8.drawString(0, 1, "ID");
while (1);
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
String incoming = "";
//String incomingADC = "";
while (LoRa.available())
incoming += (char)LoRa.read();
//incomingADC += (char)LoRa.read();
receivedText1 = incoming;
// char currentid[64];
// receivedText.toCharArray(currentid, 64);
// u8x8.drawString(4, 1, currentid);
// //print Received Text
// Serial.print(receivedText);
// print RSSI of packet
Serial.print(" ADC ");
// Serial.println(LoRa.packetRssi());
u8x8.drawString(0, 3, "ADC");
//receivedRssi = LoRa.packetRssi();
//receivedText1 = incoming;
//receivedText1 = incomingADC;
char currentid1[64];
receivedText1.toCharArray(currentid1, 64);
u8x8.drawString(5, 3, currentid1);
Serial.print(receivedText1);
receivedText = incoming;
u8x8.drawString(0, 4, "ADC1");
char currentid[64];
u8x8.drawString(5, 4, currentid);
อาจจะตอบช้าไปหน่อยนะครับ ช่วงนี้ใช้เวลากับการแก้ปัญหาระบบหลังบ้านภายในเว็บอยู่นะครับ เลยตอบได้แค่กระทู้ทั่วๆ ไป เดียวจะหาเวลามาเช็คดูให้นะครับ ช่วงนี้ลอง หาข้อมูลเพิ่มเติมดูก่อน เอามาแปะไว้ในนี้ก็ได้จะได้ช่วยๆ กันวิเคราะห์ครับ
