NodeMCU ขึ้น Error: The driver may not support this rate
หนูได้โจทย์จากอาจารย์ว่าให้ใช้เซ็นเซอร์วัดระยะทาง แสดงผลออกจากไฟLed โดยให้ระยะไกลไฟดับระยะใกล้ไฟติด หนูอยากทราบว่าที่หนูเขียนไว้ถูกไหมคะ ต้องแก้ตรงไหนบ้างขอบคุณค่ะ
โค้ต error
Executable segment sizes:
ICACHE : 32768           - flash instruction cache
IROM   : 236740          - code in flash         (default or ICACHE_FLASH_ATTR)
IRAM   : 27369   / 32768 - code in IRAM          (IRAM_ATTR, ISRs...)
DATA   : 1496  )         - initialized variables (global, static) in RAM/HEAP
RODATA : 940   ) / 81920 - constants             (global, static) in RAM/HEAP
BSS    : 25688 )         - zeroed variables      (global, static) in RAM/HEAP
Sketch uses 266545 bytes (25%) of program storage space. Maximum is 1044464 bytes.
Global variables use 28124 bytes (34%) of dynamic memory, leaving 53796 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM3
Traceback (most recent call last):
  File "C:/Users/Admin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 291, in _set_port_baudrate
    self._port.baudrate = baud
  File "C:/Users/Admin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial\serial\serialutil.py", line 299, in baudrate
    self._reconfigure_port()
  File "C:/Users/Admin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial\serial\serialwin32.py", line 224, in _reconfigure_port
    'Original message: {!r}'.format(ctypes.WinError()))
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: OSError(22, 'The I/O operation has been aborted because of either a thread exit or an application request.', None, 995)
During handling of the above exception, another exception occurred:
  File "C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in <module>
    esptool.main(cmdline)
  File "C:/Users/Admin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3551, in main
    esp = chip_class(each_port, initial_baud, args.trace)
  File "C:/Users/Admin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 279, in __init__
    self._set_port_baudrate(baud)
  File "C:/Users/Admin/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 293, in _set_port_baudrate
    raise FatalError("Failed to set baud rate %d. The driver may not support this rate." % baud)
esptool.FatalError: Failed to set baud rate 115200. The driver may not support this rate.
การต่อ
ต่อแบบไหนถ่ายมาดูหน่อยครับ ปัญหานี้เกิดจากการอัพโหลดไม่ได้ ไม่ใช่การเขียนโค้ตผิด
ครั้งแรกที่ให้ดูพอร์ตไม่เข้าค่ะ พอลองขยับแลเวอัพโหลดอีกรอบเป็นแบบนี้ค่ะ
แคปหน้านี้มาดูหน่อยครับ
แล้วโหลดตัว Driver ไปติดตั้งทำตามกระทู้นี้
ขอบคุณค่ะทำได้แล้วค่ะ
เยี่ยมมากครับ สรุปหน่อยว่าทำอะไรไปถึงได้
ทำตามที่พี่แนะนำมาเลยค่ะ ขอบคุณมากค่ะ
ขอปิดประเด็นนี้นะครับ
Tony Cavalero Hbo GIF by The Righteous Gemstones
