โค้ดครับ
#define BLYNK_TEMPLATE_ID "TMPLf_VEI5xH"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "X5zwImlUNpugTUixUBav5_NeUB345PWx"
// Comment this out to disable prints and save space
#include <PMS.h>
char Relay1 = 8;
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "E = mc2";
char pass[] = "zxkeq8vo9i931";
PMS pms(Serial);
PMS::DATA data;
byte auto_relay = 0;
float dust_auto = 0;
// Change Web Link Button message to "Congratulations!"
pinMode(Relay1, OUTPUT);
Blynk.
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
Blynk.connect();
// Set incoming value from pin V0 to a variable
if (param.asInt()==1){
analogWrite(Relay1, 255);
else{
analogWrite(Relay1, 0);
//Update state
พออัปลงบอร์ด แล้วพอปล่อย wifi มันขึ้นแบบนี้อะครับ
