โค้ดนี้ต้องต่อขายังไงบ้างครับ *มือใหม่ครับ
#define BLYNK_TEMPLATE_ID "TMPLxkfmRohc"
#define BLYNK_DEVICE_NAME "SmartFarm 2"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
#define DHTPIN 15
#define DHTTYPE DHT11
//#define APP_DEBUG
#define USE_NODE_MCU_BOARD
#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
int SensorPin = A0;
int SensorValue = 0;
const int moisture1 = 32;
const int moisture2 = 33;
const int moisture3 = 34;
const int moisture4 = 35;
int moisture_value1 = 0;
int moisture_value2 = 0;
int moisture_value3 = 0;
int moisture_value4 = 0;
bool switchStatus = 0; // 0 = manual,1=auto
int soilMoistureLimit = 0;
bool manualSwitch = 0;
bool solenoid1 = 0;
bool solenoid2 = 0;
BLYNK_WRITE(V0)
  switchStatus = param.asInt(); // Get value as integer
// update soilMosture setting
  soilMoistureLimit = param.asInt(); // Get value as integer
// update manualSwitch
BLYNK_WRITE(V5)
  manualSwitch = param.asInt();
BLYNK_WRITE(V6)
  solenoid1 = param.asInt();
BLYNK_WRITE(V7)
  solenoid2 = param.asInt();
#define PUMP D0
#define relayone D2
#define relaytwo D3
void manualAutoAction()
  moisture_value1 = analogRead(moisture1);
  moisture_value2 = analogRead(moisture2);
  moisture_value3 = analogRead(moisture3);
  moisture_value4 = analogRead(moisture4);
  Serial.print("Moisture1 = ");
  Serial.println(moisture_value1);
  Serial.print("Moisture2 = ");
  Serial.println(moisture_value2);
  Serial.print("Moisture3 = ");
  Serial.println(moisture_value3);
  Serial.print("Moisture4 = ");
  Serial.println(moisture_value4);
  if(switchStatus)
    // auto
    if(moisture_value1 < soilMoistureLimit||(moisture_value2 < soilMoistureLimit))
      digitalWrite(PUMP,HIGH);
      digitalWrite(relayone,HIGH);
      digitalWrite(PUMP,LOW);
      digitalWrite(relayone,LOW);
    if(moisture_value3 < soilMoistureLimit||(moisture_value4 < soilMoistureLimit))
      digitalWrite(relaytwo,HIGH);
      digitalWrite(relaytwo,LOW);
  //manual
    if(manualSwitch)
    if(solenoid1)
    if(solenoid2)
    // manaul
void checkTemp()
  Blynk.virtualWrite(V5, h);  //V5 is for Humidity
  Blynk.virtualWrite(V6, t);  //V6 is for Temperature
  Serial.begin(9400);
  pinMode(PUMP,OUTPUT);
  pinMode(relayone,OUTPUT);
  pinMode(relaytwo,OUTPUT);
  BlynkEdgent.begin();
  timer.setInterval(1000L, manualAutoAction);
  timer.setInterval(10000L, checkTemp);
  BlynkEdgent.run();
  SensorValue = analogRead(SensorPin);
  SensorValue = map(SensorValue, 0, 1023, 0, 100);
มี เซนเซอร์ครบหรือยังครับ
ครบทุกอย่างแล้วครับ
เบื้องต้นเราก็จะต่อขา data เข้ากับ 4 พินนี้บนบอร์ด นะครับ แต่ผมดูขาที่ใช้แล้วเหมือนเราจะใช้ esp32 มากกว่า 8266 นะนิ
ลองต่อดูบ้างรึยัง
ช่วยเปลี่ยนขา esp32 ให้เปน 8266 ให้หน่อยได่มั้ยครับ
