#include <SoftwareSerial.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define RE 12
#define DE 13
#define RE 8
#define DE 7
int ph ;
int ph2 ;
int npk;
//const byte code[]= {0x01, 0x03, 0x00, 0x1e, 0x00, 0x03, 0x65, 0xCD};
//const byte nitro[] = {0x01,0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phaddress[] = {0x01, 0x03, 0x00, 0x00, 0x00, 0x01, 0x84, 0x0A};
const byte phos[] = {0x01, 0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte pota[] = {0x01,0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
byte values[11];
SoftwareSerial mod(4,5);
SoftwareSerial mod1(2,3);
mod.begin(4800);
pinMode(RE , OUTPUT);
pinMode(DE , OUTPUT);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
display.clearDisplay();
display.setCursor(25, 15);
display.setTextSize(1);
display.setTextColor(WHITE);
display.println(" PH Sensor");
display.setCursor(25, 35);
display.print("Initializing");
display.display();
byte val1, val2, val3;
val2 = Fphaddress();
delay(250);
byte val4,val5,val6;
val4 = nitrogen();
delay(250);
val5 = phosphorous();
delay(250);
val6 = potassium();
delay(250);
ph = val2 / 10;
ph2 = val2 % 10;
Serial.print("PH: ");
Serial.print(ph);
Serial.print(ph2);
Serial.println(" pH");
Serial.print("Nitrogen: ");
Serial.print(val1);
Serial.println(" mg/kg");
Serial.print("Phosphorous: ");
Serial.print(val2);
Serial.print("Potassium: ");
Serial.print(val3);
display.setTextSize(2);
display.setCursor(5, 20);
display.print("PH: ");
display.print(ph);
display.print(".");
display.print(ph2);
display.print(" pH");
display.setCursor(0, 5);
display.print("N: ");
display.print(val1);
display.print(" mg/kg");
display.setCursor(10, 55);
display.print("www.cybertice.com");
display.display();
byte Fphaddress() {
digitalWrite(DE, HIGH);
digitalWrite(RE, HIGH);
if (mod.write(phaddress, sizeof(phaddress)) == 8) {
digitalWrite(DE, LOW);
digitalWrite(RE, LOW);
for (byte i = 0; i < 7; i++) {
values[i] = mod.read();
return values[4];
byte nitrogen(){
digitalWrite(DE ,HIGH);
digitalWrite(RE ,HIGH);
if(mod.write(nitro,sizeof(nitro))==8){
digitalWrite(DE ,LOW);
digitalWrite(RE ,LOW);
for(byte i=0;i<7;i++){
//Serial.print(mod.read(),HEX);
Serial.print(values[i],HEX);
return values[4];
byte phosphorous(){
if(mod.write(phos,sizeof(phos))==8){
return values[4];
byte potassium(){
if(mod.write(pota,sizeof(pota))==8){
return values[4];
Copy ส่วน error มาวางด้วยครับ เลือกบอร์ดถูกรึป่าว
