พอดีว่าจะอัพใส่ บอร์ดเเล้วขึ้นแบบนี้
แต่พอลองอัพโค้ด example อื่นๆอัพได้ปกติ
Copy Code มาวางเลยครับ
ไฟล์แรก
adafruitio_15_temp.ino
#include "config.h"
#include <Adafruit_Sensor.h>
#include <DHT_U.h>
#define DATA_PIN 2
DHT_Unified dht(DATA_PIN, DHT22);
AdafruitIO_Feed *temperature = io.feed("temperature");
AdafruitIO_Feed *humidity = io.feed("humidity");
// start the serial connection
while(! Serial);
Serial.print("Connecting to Adafruit IO");
io.connect();
while(io.status() < AIO_CONNECTED) {
Serial.println(io.statusText());
io.run();
sensors_event_t event;
float celsius = event.temperature;
float fahrenheit = (celsius * 1.8) + 32;
Serial.print("celsius: ");
Serial.print(celsius);
Serial.println("C");
Serial.print("fahrenheit: ");
Serial.print(fahrenheit);
Serial.println("F");
temperature->save(fahrenheit);
Serial.print("humidity: ");
Serial.print(event.relative_humidity);
Serial.println("%");
humidity->save(event.relative_humidity);
ไฟล์ที่2
config.h
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME "your_username"
#define IO_KEY "your_key"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
// - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
// - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
// - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
// - Feather M0 WiFi -> https://www.adafruit.com/products/3010
// - Feather WICED -> https://www.adafruit.com/products/3056
// - Adafruit PyPortal -> https://www.adafruit.com/product/4116
// - Adafruit Metro M4 Express AirLift Lite ->
// https://www.adafruit.com/product/4000
// - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
// - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
// - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID "your_ssid"
#define WIFI_PASS "your_pass"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// uncomment the following line if you are using mrk1010 or nano 33 iot
//#define ARDUINO_SAMD_MKR1010
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) || \
defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9 // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
// - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
// - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
แก้ไขได้เเล้วครับ
ติดที่ โค้ดบรรทัด // #include “AdafruitIO_FONA.h” ติดที่ lib เอามาใช้
เยี่ยมมากครับขอบคุณที่อัพเดท
