เชื่อมกับตัว blynk ไม่ได้อ่ะครับเกิดจากอะไรหรอครับ
/* Connections
Relay. D3
Btn. D7
Soil. A0
PIR. D5
SDA. D2
SCL. D1
Temp. D4
//Include the library files
//Initialize the LCD display
LiquidCrystal_I2C lcd(0x3F, 16, 2);
char auth[] = "7UhKHyRUTFJWpM2rPlnykqpwo2nTTD4v"; //Enter your Blynk Auth token
char ssid[] = "Natthawat.man"; //Enter your WIFI SSID
char pass[] = "123456789"; //Enter your WIFI Password
DHT dht(D4, DHT11);//(DHT sensor pin,sensor type) D4 DHT11 Temperature Sensor
//Define component pins
#define soil A0 //A0 Soil Moisture Sensor
#define PIR D5 //D5 PIR Motion Sensor
int PIR_ToggleValue;
void checkPhysicalButton();
int relay1State = LOW;
int pushButton1State = HIGH;
#define RELAY_PIN_1 D3 //D3 Relay
#define PUSH_BUTTON_1 D7 //D7 Button
#define VPIN_BUTTON_1 V12
//Create three variables for pressure
double T, P;
char status;
lcd.begin();
lcd.backlight();
pinMode(PIR, INPUT);
pinMode(RELAY_PIN_1, OUTPUT);
digitalWrite(RELAY_PIN_1, LOW);
pinMode(PUSH_BUTTON_1, INPUT_PULLUP);
digitalWrite(RELAY_PIN_1, relay1State);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
lcd.setCursor(0, 0);
lcd.print(" Initializing ");
for (int a = 5; a <= 10; a++) {
lcd.setCursor(a, 1);
lcd.print(".");
lcd.clear();
lcd.setCursor(11, 1);
lcd.print("W:OFF");
//Call the function
timer.setInterval(100L, soilMoistureSensor);
timer.setInterval(100L, DHT11sensor);
timer.setInterval(500L, checkPhysicalButton);
//Get the DHT11 sensor values
void DHT11sensor() {
Blynk.virtualWrite(V0, t);
Blynk.virtualWrite(V1, h);
lcd.print("T:");
lcd.print(t);
lcd.setCursor(8, 0);
lcd.print("H:");
lcd.print(h);
//Get the soil moisture values
void soilMoistureSensor() {
int value = analogRead(soil);
value = map(value, 0, 1024, 0, 100);
value = (value - 100) * -1;
Blynk.virtualWrite(V3, value);
lcd.setCursor(0, 1);
lcd.print("S:");
lcd.print(value);
lcd.print(" ");
//Get the PIR sensor values
void PIRsensor() {
bool value = digitalRead(PIR);
if (value) {
Blynk.logEvent("pirmotion","WARNNG! Motion Detected!"); //Enter your Event Name
WidgetLED LED(V5);
LED.on();
WidgetLED LED(V5);
LED.off();
BLYNK_WRITE(V6)
PIR_ToggleValue = param.asInt();
// Request the latest state from the server
Blynk.syncVirtual(VPIN_BUTTON_1);
BLYNK_WRITE(VPIN_BUTTON_1) {
relay1State = param.asInt();
if (digitalRead(PUSH_BUTTON_1) == LOW) {
// pushButton1State is used to avoid sequential toggles
if (pushButton1State != LOW) {
// Toggle Relay state
relay1State = !relay1State;
// Update Button Widget
Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
pushButton1State = LOW;
if (PIR_ToggleValue == 1)
lcd.setCursor(5, 1);
lcd.print("M:ON ");
PIRsensor();
lcd.print("M:OFF");
WidgetLED LED(V5);
LED.off();
if (relay1State == HIGH)
lcd.print("W:ON ");
else if (relay1State == LOW)
lcd.print("W:OFF");
Blynk.run();//Run the Blynk library
timer.run();//Run the Blynk timer
