แอพ blynk ขึ้น wasn't online yet
โค๊ดที่ใช้
#define BT1 D1
#define BT2 D2
#define BT3 D3
char auth = “ZYz6K1VbTEg-nJ7QBoP5m0HmL1m5b1bQ”;
char ssid = “YaHoo”;
char pass = “123456789”;
WidgetLCD lcd1(V0);
WidgetLED BT1Blynk(V10);
WidgetLED BT2Blynk(V11);
WidgetLED BT3Blynk(V12);
digitalWrite(BT1, LOW);
digitalWrite(BT2, LOW);
digitalWrite(BT3, LOW);
lcd1.clear();
lcd1.print(3,0,"Smart Fan");
lcd1.print(5,1,"Controller");
pinMode(BT1,OUTPUT);
pinMode(BT2,OUTPUT);
pinMode(BT3,OUTPUT);
BLYNK_WRITE(V1){
if (param.asInt()){
    digitalWrite(BT1, HIGH);
 lcd1.clear();
 lcd1.print(4,0,"On Number");
 lcd1.print(8,1,"1");
 BT1Blynk.on();
 BT2Blynk.off();
 BT3Blynk.off();
 Blynk.virtualWrite(V2,0);
 Blynk.virtualWrite(V3,0);
  lcd1.clear();
  lcd1.print(7,0,"Off");
  BT1Blynk.off();
BLYNK_WRITE(V2){
if (param.asInt()){
  digitalWrite(BT2, HIGH);
 lcd1.clear();
 lcd1.print(8,1,"2");
 BT2Blynk.on();
 BT1Blynk.on();
 BT1Blynk.off();
 BT3Blynk.off();
 Blynk.virtualWrite(V1,0);
    lcd1.clear();
     BT2Blynk.off();
BLYNK_WRITE(V3){
if (param.asInt()){
  digitalWrite(BT3, HIGH);
 lcd1.clear();
 lcd1.print(8,1,"3");
  BT3Blynk.on();
 BT1Blynk.off();
 BT2Blynk.off();
    lcd1.clear();
     BT3Blynk.off();
BLYNK_WRITE(V4){
lcd1.clear();
lcd1.print(5,0,"Off All");
BT1Blynk.on();
BT1Blynk.off();
BT2Blynk.off();
BT3Blynk.off();
เลือก server ผิดครับ ใช้ของอะไร
ผมใช้อันนี้ครับ
ทำตามนี้ครับ
ถ้าผมจะใช้กับโค๊ดที่ผมมีผมต้องแก้ไขตรงไหนบ้างครับ
ตอนนี้ทำได้แล้วครับขอบคุณมากๆครับ
