ใช้บอร์ดอะไรถ่ายมาดูหน่อย copy error full มาวางด้วย
ใช้บอร์ด NodeMCU V3 Lua WIFI Module ESP8266
โค้ต
#define WIFI_SSID "JONG" /////////////*************แก้
#define WIFI_PASSWORD "0810761818"////////**************แก้
#define LINE_TOKEN_PIR "tegKwq93lgdCOxCHYHGOsMSywRhSK34PTnYY0hd5DWe"////***************แก้
#define PirPin D6
#define DHTPIN D7
#define DHTTYPE DHT11
String message1 = "tessssssssssssssssssssssst";//****************แก้
bool beep_state = false;
bool send_state = false;
uint32_t ts, ts1, ts2;
pinMode(PirPin, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("connecting");
WiFi.mode(WIFI_STA);
Serial.print("connecting");
Serial.print("connected: ");
delay(10000);
read_sensor();
ts = ts1 = ts2 = millis();
ts = millis();
if ((ts - ts2 >= 60000) && (WiFi.status() == WL_CONNECTED)) {
read_sensor();
beep_state = false;
Serial.println("Detect !");
Line_Notify1(message1);
beep_state = true;
WiFiClientSecure client;
String req = "";
req += "\r\n";
req += "message=" + message1;
// Serial.println(req);
while (client.connected()) {
if (line == "\r") {
void read_sensor() {
Serial.print(t);
Serial.println(" *C ");
โค้ดerror
Arduino: 1.8.11 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\premp\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp:15:
C:\Users\premp\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.h:36:10: fatal error: Adafruit_Sensor.h: No such file or directory
36 | #include <Adafruit_Sensor.h>
compilation terminated.
ติดตั้งตัวนี้รึยัง
ขอบคุณครับผ่านแล้วครับ
แก้โดยการติดตั้ง Adafruit_Sensor.h
