เชื่อมต่อแล้วแต่ตอนส่งข้อความทางไลน์ขึ้นfail
โค้ต
#define WIFI_SSID "JONG" /////////////*************แก้
#define WIFI_PASSWORD "0810761818"////////**************แก้
#define LINE_TOKEN_PIR "Or6wlLP2MAKGly4lcxmbs2Jz3iIcrb01EaLbFrlKIfh"////***************แก้
#define PirPin D6
#define DHTPIN D7
#define DHTTYPE DHT11
String message1 = "TESSSSSSSSSSSSSST";//****************แก้
bool beep_state = false;
bool send_state = false;
uint32_t ts, ts1, ts2;
pinMode(PirPin, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("connecting");
WiFi.mode(WIFI_STA);
Serial.print("connecting");
Serial.print("connected: ");
delay(10000);
read_sensor();
ts = ts1 = ts2 = millis();
ts = millis();
if ((ts - ts2 >= 60000) && (WiFi.status() == WL_CONNECTED)) {
read_sensor();
beep_state = false;
Serial.println("Detect !");
Line_Notify1(message1);
beep_state = true;
WiFiClientSecure client;
String req = "";
req += "\r\n";
req += "message=" + message1;
// Serial.println(req);
while (client.connected()) {
if (line == "\r") {
void read_sensor() {
Serial.print(t);
Serial.println(" *C ");
