แนะนำการเชื่อมต่อ กับแอป กับเซิฟเวอร์หน่อยครับ
#include <Blynk.h>
#include <Adafruit_Sensor.h>
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
#define BLYNK_TEMPLATE_ID "TMPLdULjnAbn"
#define BLYNK_DEVICE_NAME "Smartfarm"
#define BLYNK_AUTH_TOKEN "6c85MxoHZGWub7wIOCfM0Z71wF008mHa"
#include <TimeLib.h>
//#define DHTPIN G34
//#define MOISURE_READ
#define VALVE_ON 0
#define VALVE_OFF 1
#define BLYNK_TEMPERATURE V0
#define BLYNK_HUMIDITY V1
#define BLYNK_SOILMOISTURE V2
#define BLYNK_FAN V3
#define BLYNK_VALVE V4
#define DHTPIN 34
#define DHTTYPE DHT11
//DHTesp dht;
const int DHT_TEMPERATURE_READ = 34;
char auth[] = "BLYNK_AUTH_TOKEN";
char ssid[] = "RO_2.4G";
char pass[] = "0983132093";
/*Serial.println();
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED){
Serial.println("WiFi connected.");
Serial.println("connected");
// Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
//delay(dht.getMinimumSamplingPeriod());
float humidity = dht.readHumidity(); // ดึงค่าความชื้น
float temperature = dht.readTemperature(); // ดึงค่าอุณหภูมิ
//Serial.print(dht.getStatusString());
Serial.print("\t");
Serial.print(humidity, 1);
Serial.print("\t\t");
Serial.print(temperature, 1);
//Serial.println(dht.toFahrenheit(temperature), 1);
Blynk.virtualWrite(V0, temperature);
Blynk.virtualWrite(V1, humidity);
//Blynk.run();
//update_blynk_data();
