สอบถามเรื่องโค้ดการใช้งานครับ
พอดีโค้ดมันรับค่าได้แล้ว แต่หยอดเหรียญเครื่องทำงานปกติแต่ ไลน์ไม่เด้ง
#include <WiFiManager.h>
#define LINE_TOKEN  "utaElHMnTZRVZFvKZSGAgUxlF7Fzlgwg0flppaKwUHX"
LiquidCrystal_I2C lcd(0x27,16,2);
int sensor = 5;
int i = 0;
int a = 0; // Total amount
int ten = 0;
int ten10 = 0; // 10-coin type
int five = 0;
int five5 = 0; // 5-coin type
int two = 0;
int two2 = 0; // 2-coin type
int one = 0;
int one1 = 0; // 1-coin type
int i10 = 0; // Counter for types
int i5 = 0;
int i2 = 0;
int i1 = 0;
//char LINE_TOKEN[43] = "Input Line notify Token";
void saveConfigCallback () {
  shouldSaveConfig = true;
ESP8266WebServer server(80);
void handleRoot() {
  server.send(200, "text/plain", "เชื่อมต่อ...");
void ICACHE_RAM_ATTR doCounter();
  Serial.println("Connecting...");
  if (!wifiManager.startConfigPortal("All")) {
    Serial.println("NO");
    ESP.reset();
  pinMode(sensor, INPUT);
  attachInterrupt(digitalPinToInterrupt(sensor), doCounter, FALLING);
  server.on("/", handleRoot);
  server.begin();
  lcd.begin();
  lcd.backlight();
  lcd.print("Project");
  lcd.setCursor(0, 1);
  lcd.print("Smart Piggybank");
boolean isCounter = false;
int count = 0;
  if (isCounter == true) {
    isCounter = false;
  if (i != 1000 && count != 0 ) {
    i = i + 1;
  if (i == 1000) {
    i = 0;
    if (count == 10){
      i10 = i10 + 1;
      ten = i10 * 10;
      ten10 = 10;
    if (count == 5){
      i5 = i5 + 1;
      five = i5 * 5;
      five5 = 5;
    if (count == 2){
      i2 = i2 + 1;
      two = i2 * 2;
      two2 = 2;
    if (count == 1){
      i1 = i1 + 1;
      one = i1 * 1;
      one1 = 1;
    a = ten + five + two + one;
    // Sending Line Notify
    String message1 = "กระปุกออมสินอัจฉริยะ\n";
    String messageCoins10 = "เหรียญ 10: ";
    messageCoins10 += String(i10);
    messageCoins10 += " เหรียญ\n";
    String messageCoins5 = "เหรียญ 5: ";
    messageCoins5 += String(i5);
    messageCoins5 += " เหรียญ\n";
    String messageCoins2 = "เหรียญ 2: ";
    messageCoins2 += String(i2);
    messageCoins2 += " เหรียญ\n";
    String messageCoins1 = "เหรียญ 1: ";
    messageCoins1 += String(i1);
    messageCoins1 += " เหรียญ\n";
    String totalMessage = "รวมเงิน ";
    totalMessage += String(a);
    totalMessage += " บาท";
    LINE.notify((message1 + messageCoins10 + messageCoins5 + messageCoins2 + messageCoins1 + totalMessage).c_str());
    // Display on LCD
    lcd.begin();
    lcd.backlight();
    lcd.setCursor(2, 0);
    lcd.print("Total");
    lcd.setCursor(9, 0);
    lcd.print("Money");
    lcd.setCursor(3, 1);
    lcd.print(a);
    lcd.setCursor(10, 1);
    lcd.print("Baht");
    server.handleClient();
    count = 0;
void doCounter() {
  isCounter = true;
  count++;
โค้ตยำมาเละเทะ เลยครับเิร่มต้นจากโค้ตนี้ดีกว่าครับ
ลอง debug ดูไหมครับ
Serial.println("Before LINE.notify() call");
Serial.println("After LINE.notify() call");
อีกแบบ
bool success = LINE.notify((message1 + messageCoins10 + messageCoins5 + messageCoins2 + messageCoins1 + totalMessage).c_str());
if (!success) {
    Serial.println("Line Notify failed");
