คอมไพล์ไม่ผ่านครับ ขอแนวทางในการแก้ปัญหาที่
เบื้องต้นเอาโค้ตที่ใช้มาดูก่อนครับ
#include <PZEM004T.h>
#include <ThingspeakClient.h>
#define FIRST_ADDRESS 0
#define MAX_ATTEMPTS 10
#define min(a,b) ((a)<(b)?(a):(b))
PZEM004T pzem(4, 5); // RX,TX d2,d1
IPAddress ip(192, 168, 1, 1);
const char* ssid     = "OPPO A3s";
const char* password = "12345678";
char auth[] = "04ce50cb7a4449e4aa7bafa522ba940f";  //Blynk Token
WiFiClient client;
ThingspeakClient thingspeak;
const char* host = "api.thingspeak.com";
const String THINGSPEAK_CHANNEL_ID = "683646";
const String THINGSPEAK_API_READ_KEY = "URRA3UQFM692SFRC";  //read key
const char* api   = "Q3KABRVWS5DHMD4F";  //write key
float v, i, p, e, b;
long milisec = 0;
float calBill(float Unit, float ft, bool over_150_Unit_per_month = false) ;
float FT = -15.9;
int firstState;
void Line_Notify(String message);
int token = 0;
String LINE_TOKEN[2]    = {"JRULp8eXBAtxzq68GpBvpQHaAp4peqemm1sdNWkiDAF", "JP4jxAIj4F3rRuHzvId18OFCqIz8mSgA1RKpBn0FHnx"};  //line token
unsigned long currentMillis, previousMillis, previousMillis2, previousMillis3, readMillis = 0;
String message = "%20Volt%20";  // " Volt "
String message2 = "%20Current%20";  //  " Current "
String message3 = "%20Power%20Now%20";  //  " Power Now "
String message4 = "%20Energy%20";  //  " Energy "
String message5 = "%20Cost%20";  //  " Cost "
String message6 = "%20Warning%20overload%20";  //  "  Warning overload "
String message7 = "%20Power%20Total%20";  //  " Power Total "
  pzem.setAddress(ip);
  EEPROM.begin(512);
  firstState = EEPROM.read(FIRST_ADDRESS);
  Serial.println(firstState);
  if (firstState == 5) {
    Serial.print("use again:");
    thingspeak.getLastChannelItem(THINGSPEAK_CHANNEL_ID, THINGSPEAK_API_READ_KEY);
    String f1 = (thingspeak.getFieldValue(3));
    String f2 = (thingspeak.getFieldValue(4));
    String f3 = (thingspeak.getFieldValue(5));
    e = f1.toFloat();
    b = f2.toFloat();
    FT = f3.toFloat();
    Serial.print("use new:");
    Serial.println("first write eeprom");
    EEPROM.write(0, 5);
    EEPROM.commit();
  ReadPzem();
  SendNormal();
  currentMillis = previousMillis = previousMillis2 = previousMillis3 = readMillis = millis();
  Serial.println(FT);
  Blynk.virtualWrite(V7, FT);
  b = calBill(e, FT, true);
  currentMillis = millis();
  if (currentMillis - readMillis >= 1000) {
    ReadPzem();
    SetBlynk();
  if (currentMillis - previousMillis3 >= 30000) UpdateThingspeak();
  if (currentMillis - previousMillis >= 900000) SendNormal();
  if (i >= 2.00 && currentMillis - previousMillis2 >= 60000) SendWarning();
void ReadPzem() {
  unsigned long time;
  v = getVoltage();
  i = getCurrent();
  p = v * i;
  if (p >= 1) {
    time += 1;
    e += (p * time) / (1000 * 3600);
    time = 0;
  Serial.print("Volt: "); Serial.print(v); Serial.print("V\n");
  Serial.print("Current: "); Serial.print(i); Serial.print("A\n");
  Serial.print("power Now: "); Serial.print(p); Serial.print("W\n");
  Serial.print("Energy: "); Serial.print(e, 3); Serial.print("kWh\n");
  Serial.print("Cost: "); Serial.print(b, 3); Serial.print("฿\n");
  Serial.print("FT: "); Serial.println(FT);
  Serial.println("--------------------");
void SetBlynk() {
  Blynk.virtualWrite(V0, v);
  Blynk.virtualWrite(V1, i);
  Blynk.virtualWrite(V2, p);
  Blynk.virtualWrite(V4, e);
  Blynk.virtualWrite(V5, b);
  Blynk.virtualWrite(V6, FT);
void UpdateThingspeak() {
  previousMillis3 = millis();
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
  String etemp = String(e, 3);
  String btemp = String(b, 3);
  // We now create a URI for the request
  String url = "/update?api_key=";
  url += api;
  url += "&field1=";
  url += v;
  url += "&field2=";
  url += i;
  url += "&field3=";
  url += p;
  url += "&field4=";
  url += etemp;
  url += "&field5=";
  url += btemp;
  url += "&field6=";
  url += FT;
  Serial.print("Requesting URL: ");
  Serial.println(url);
  // This will send the request to the server
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  // Read all the lines of the reply from server and print them to Serial
  while (client.available()) {
    Serial.print(line);
void SendNormal() {
  previousMillis = millis();
  token = 0;
  Line_Notify(message + v + "V" + message2 + i + "A" + message3
              + p + "W" + message4 + e + "Wh" + message5 + b + "฿");
void SendWarning() {
  previousMillis2 = millis();
  token = 1;
  Line_Notify(message6 + i + "A");
BLYNK_WRITE(V7) {
  FT = param[0].asFloat();
BLYNK_WRITE(V8) {
  p = 0.0;
  e = 0.0;
  b = 0.0;
float calBill(float Unit, float ft, bool over_150_Unit_per_month) {
  float Service = over_150_Unit_per_month ? 38.22 : 8.19;
  float total = 0;
  if (!over_150_Unit_per_month) {
    float Rate15 = 2.3488;
    float Rate25 = 2.9882;
    float Rate35 = 3.2405;
    float Rate100 = 3.6237;
    float Rate150 = 3.7171;
    float Rate400 = 4.2218;
    float RateMore400 = 4.4217;
    if (Unit >= 6) total += min(Unit, 15) * Rate15;
    if (Unit >= 16) total += min(Unit - 15, 10) * Rate25;
    if (Unit >= 26) total += min(Unit - 25, 10) * Rate35;
    if (Unit >= 36) total += min(Unit - 35, 65) * Rate100;
    if (Unit >= 101) total += min(Unit - 100, 50) * Rate150;
    if (Unit >= 151) total += min(Unit - 150, 250) * Rate400;
    if (Unit >= 401) total += (Unit - 400) * RateMore400;
    float Rate150 = 3.2484;
    total += min(Unit, 150) * Rate150;
  total += Service;
  total += Unit * (ft / 100);
  total += total * 7 / 100;
  return total;
  WiFiClientSecure client;
  String req = "";
  req += "Authorization: Bearer " + String(LINE_TOKEN[token]) + "\r\n";
  req += "\r\n";
  req += "message=" + message;
  delay(30);
  while (client.connected()) {
    if (line == "\r") {
float getVoltage() {
  int i = 0;
  float r = -1.0;
  do {
    r = pzem.voltage(ip);
    wdt_reset();
    i++;
  } while ( i < MAX_ATTEMPTS && r < 0.0);
  return r;
float getCurrent() {
  int i = 0;
  float r = -1.0;
  do {
    r = pzem.current(ip);
    wdt_reset();
    i++;
  return r;
ผมลองลงไลบารี่ใหม่ ตอนนี้เป็นแบบนี้แทนครับ
เวลาเอาโค้ตมาวางทำให้เป็นฟอร์มด้วยนะครับ จะได้ดูง่ายขึ้น
โหลด ThingspeakClient.h มาวางใน โฟเดอร์ library ครับ
วางแล้วครับ แต่ก็ยังขึ้นเหมือนเดิม
วางตรงไหนครับ
นี่ครับ มันกลายเป็นแบบนี้แทน
ลองแก้ชื่อโฟเดอร์ เป็น -master ต่อท้านเหมือนตัวอื่นดูครับ
ยังเป็นเหมือนเดิมครับ
ตอนนี้มันขึ้นว่าอ่ะไรแคปมาดูหน่อยครับ
เช็คว่าลงแบบนี้ครบยัง
ของผมมันหาตัวนี้ไม่เจอครับ
นีครับ ตอนนี้เป็นแบบนี้
http://arduino.esp8266.com/stable/package_esp8266com_index.json
copyโ ค้ดนี้ไปใส่ใน File> prefernces
ลองทำตามทุกวิธีแล้วครับแต่ก็ยังเหมือนเดิม
Arduino: 1.8.8 (Windows 8), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
exit status 2
“Show verbose output during compilation”
เดะดึกๆ ผมลองเทสโค้ตดูก่อนครับ
โอเครครับ ผมจะลองหาวิธีแก้ไปด้วย
ผมติดตัวเดียวกัน แต่แก้ผ่านละครับ
