จะทำสมาร์ทฟาร์มครับ คือ ตัวที่ส่งไปยัง blynk ทำได้ค่อนข้างจะสมบูรณ์แล้ว
ติด 2 ที่ คือ (1).ตั้ง Timer แล้วไม่ทำงาน (2).ปุ่ม manual หน้าตู้ ผมทำให้มันลิ้งกันไม่ได้
#include <SPI.h>
#include <Ethernet.h>
#define DHTPIN D2
#define DHTTYPE DHT11
#define wifiLed LED_BUILTIN
int sensorPin = A0;
int sensorValue = 0;
int led1 = D0;
int led2 = D1;
int Relay = D3;
int botton1 = D5;
int botton2 = D6;
bool auto_on = false;
//SimpleTimer timer;
WidgetLCD lcd(V6);
//#include "Timer.h"
#define VPIN_BUTTON_1 V3
#define VPIN_BUTTON_2 V4
int toggleState_1 = 1;
int wifiFlag = 0;
int SetMin;
int SetMax;
BLYNK_WRITE(V10) //set soil Moisture sensor slider in app on pin V10
SetMin = param.asInt();
BLYNK_WRITE(V11) //set soil Moisture sensor slider in app on pin V11
SetMax = param.asInt();
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
//#include "BottonManual.h"
//#include "RelayOnOff.h"
BLYNK_WRITE(V4) {
if (param.asInt() == 1)
{ auto_on = false;
digitalWrite(Relay, HIGH);
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
lcd.clear();
lcd.print(0, 0, "PUMP: ON");
lcd.print(0, 1, "STATS: MANUAL");
Blynk.virtualWrite(V3, LOW);
if (param.asInt() == 0)
{ //auto_on = true;
digitalWrite(Relay, LOW);
lcd.clear();
lcd.print(0, 0, "PUMP: OFF");
//Blynk.virtualWrite(V4, LOW);
void without_internet2() {
//Manual Switch Control
if (digitalRead(botton2) == HIGH) {
delay(200);
auto_on = false;
lcd.clear();
if (digitalRead(botton2) == LOW) {
lcd.clear();
BLYNK_WRITE(V7) // Timer 1
{ digitalWrite(Relay, HIGH);
lcd.clear();
lcd.print(0, 1, "STATS: TIMER 1");
{ digitalWrite(Relay, LOW);
lcd.clear();
BLYNK_WRITE(V8) // Timer 2
lcd.clear();
lcd.print(0, 1, "STATS: TIMER 2");
lcd.clear();
BLYNK_WRITE(V9) // Timer 3
lcd.clear();
lcd.print(0, 1, "STATS: TIMER 3");
lcd.clear();
void sendTemp() {
Blynk.virtualWrite(V1, t);
Blynk.virtualWrite(V2, h);
void sendSoilValue() {
sensorValue = map(sensorValue, 0, 1023, 0, 100);
Blynk.virtualWrite(V5, sensorValue);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
digitalWrite(wifiLed, HIGH); //Turn off WiFi LED
if (isconnected == true) {
wifiFlag = 0;
digitalWrite(wifiLed, LOW); //Turn on WiFi LED
pinMode(sensorPin, INPUT);
pinMode(DHTPIN, INPUT);
pinMode(botton1, INPUT);
pinMode(botton2, INPUT);
pinMode(led1, OUTPUT); // กำหนดขาทำหน้าที่ให้ขา D0 เป็น OUTPUT
pinMode(led2, OUTPUT); // กำหนดขาทำหน้าที่ให้ขา D1 เป็น OUTPUT
pinMode(Relay, OUTPUT);
digitalWrite(botton1, LOW);
digitalWrite(botton2, LOW);
lcd.clear();
lcd.print(5, 0, "SMART");
lcd.print(0, 1, "Watering System");
lcd.clear();
lcd.print(0, 0, "Please Wait");
delay(300);
lcd.print(0, 0, "Please Wait.");
delay(300);
lcd.print(0, 0, "Please Wait..");
delay(300);
lcd.print(0, 0, "Please Wait...");
delay(300);
lcd.print(0, 0, "Please Wait....");
lcd.clear();
delay(800);
lcd.clear();
timer.setInterval(1000L, sendTemp);
timer.setInterval(1000L, sendSoilValue);
if (auto_on == true) {
if (sensorValue > SetMin && sensorValue < SetMax) {
digitalWrite(led1, HIGH);
digitalWrite(led2, LOW);
lcd.clear();
lcd.print(0, 1, "STATS: AUTO");
if (sensorValue < SetMin) {
lcd.clear();
else if (sensorValue > SetMax) {
lcd.clear();
BLYNK_WRITE(V3) {
//sensorValue = analogRead(sensorPin);
//sensorValue = map(sensorValue, 0, 1023, 0, 100);
{ auto_on = true;
lcd.clear();
{ auto_on = false;
lcd.clear();
//Blynk.virtualWrite(V3, LOW);
void without_internet1() {
if (digitalRead(botton1) == HIGH) {
delay(200);
auto_on = true;
lcd.clear();
if (digitalRead(botton1) == LOW) {
auto_on = false;
lcd.clear();
